It is currently Mon Aug 17, 2026 2:57 am
 Post subject: g'mic won't start/libgdk-win32-2.0-0.dll is missing?
PostPosted: Tue Aug 18, 2015 3:08 am  (#1)
OS Version: Microsoft Windows 8.1, 64 bit
Hello!
I just had to re-upload the newest version of Gimp -long story, but it works great now...except when I try to install g'mic. I try to run the application in users>username>.gimp-2.8, but run into this "the program can't start because libgdk-win32-2.0-0.dll is missing from your computer. Try re-installing the program to fix this problem." - I remember coming across this before, but can't remember what to do (I have tried reinstalling, but with same results) help! I love g'mic! :gaah
Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind.
Dr. Seuss (Theodore Lesieg)
 Post subject: Re: g'mic won't start/libgdk-win32-2.0-0.dll is missing?
PostPosted: Tue Aug 18, 2015 5:48 am  (#2)
...snip I try to run the application in users>username>.gimp-2.8, but run into this "the program can't start because libgdk-win32-2.0-0.dll is missing from your computer. Try re-installing the program to fix this problem."
Crystal ball says you are trying to run the plug-in as a stand-alone application.
It is a plug-in, run from within Gimp, bottom of the Filters menu
PostPosted: Tue Aug 18, 2015 5:58 am  (#3)
...well that's embarrassing! for some reason, I thought I had to jump more hoops or something...
