It is currently Sat Nov 28, 2026 1:01 pm
 Post subject: G'MIC plug-in for GIMP now manage high-bit depth
PostPosted: Tue Sep 08, 2015 11:55 am  (#1)
Hello folks,
Some good news to announce : With the help of some GIMP devs, I've managed to update the G'MIC plug-in code (for GIMP), so that it is now able to read/write image data from/to GIMP using high-bit depth buffers.
As you may know, GIMP 2.9 (development version) has introduced the possibility to choose the image precision among many different options, including 16bits and 32bits/channels precision. The G'MIC plug-in is now able to deal with these high-bit precision buffers, and as G'MIC does all its computation with float-valued data internally, you are sure not to loose any precision during the whole G'MIC pipeline.
I wrote a step-by-step instruction to test the newest version of the G'MIC plug-in (it requires a special compilation procedure for GIMP 2.9) here :
https://discuss.pixls.us/t/gmic-plug-in ... h-support/
Do not hesitate to test and give me feedback!
Cheers,
David.
 Post subject: Re: G'MIC plug-in for GIMP now manage high-bit depth
PostPosted: Tue Sep 08, 2015 2:06 pm  (#2)
No real report except to say it compiles here and works (so far). Used your directions with no problem (except a good few MB of git stuff and dev files)
System is: old X61 Thinkpad, 32 bit Linux Mint 17.2, Gimp 2.9.1 from otto-kesselgulasch ppa
My usual test image, changed to 16 bit floating, applied Gmic filter, saved.
Screenshot: the image re-opened. G'mic open
+ a terminal with IM identify. Yes, says 16 bit
PostPosted: Tue Sep 08, 2015 2:26 pm  (#3)
Thanks for the report James. I hope everything goes well for you.
I see you are very active on the GIMP forum and you often suggest installing the G'MIC plug-in, so let me thank you again for spreading the word :)
PostPosted: Sun Sep 13, 2015 10:28 am  (#4)
Unfortunately for me on Vista 32bit lot of errors. Any help?
The file text compilation too large for use "Code" - added for annex.
Edit:04-07-2016 compilation 1.7.4 pre without problems.
PostPosted: Wed Sep 16, 2015 6:53 am  (#5)
gimp 2.9.1 today git
gmic git
debian 64, my build
Some test and all work fine.
PostPosted: Sat Jul 02, 2016 9:31 am  (#6)
David.
Not a problem, just a query.
Has the experiment ended? No https://github.com/dtschump/gmic-minimal
This is Gimp 2.9.3 & 32 bit int in Kubuntu and the last gmic-minimal I got. For Gimp 2.8?
edit: Forget this last bit. Forgot to disable a regular g'mic
PostPosted: Sat Jul 02, 2016 10:23 am  (#7)
Hello James, the git repo 'gmic-minimal' have been merged recently with the repo 'gmic'
(size of the latter repo has been shrink to a reasonnable size).
You should be able to clone repo 'gmic' just as well. Let me know.
PostPosted: Sat Jul 02, 2016 10:56 am  (#8)
Got it, thanks. 1.7.4pre070216
PostPosted: Mon Jul 04, 2016 9:40 am  (#9)
I compiled it (without opencv) and tested the gimp plugin with Win10 64Bit. I tested it with a 16Bit TIF.
It works great!
Thanks a lot!
Hatti
PostPosted: Mon Jul 04, 2016 12:05 pm  (#10)
Also for Vista 32bit - compilation 1.7.4 without problems.
Thanks David.
