Hi David (and all G'MIC fans)
still experimenting the G'MIC Bokeh filter
another "strange" (IMO) behaviour:
a- make an oval selection on the image/active layer
b- apply the Bokeh filter
b1- in addition of getting two layers in output (previous question), the image is cut to the size of the rectangle imbedding the oval selection and the filter applied to this rectangle
c- instead of the Bokeh filter, apply a different one (still GMIC), for instance Plasma
c1- you get correctly the filter applied to the oval selection and the image is kept in its dimension
is the Bokeh filter code somehow incomplete?
a input (there is an oval selection even if you do not see it)
b output of bokeh
c output of plasma
