It is currently Sun Nov 29, 2026 6:37 pm
 Post subject: Control Montage Dimensions?
PostPosted: Thu Nov 05, 2015 9:17 pm  (#1)
Is it possible to control the dimensions of montages from the command line? I'd like to make montages that are the dimensions of my laptop (1600x900) but haven't seen documentation that describes this.
 Post subject: Re: Control Montage Dimensions?
PostPosted: Fri Nov 06, 2015 12:14 am  (#2)
serche wrote:
Is it possible to control the dimensions of montages? I'd like to make montages that are the dimensions of my laptop (1600x900) but haven't seen documentation that describes this.
I think if you start off with a canvas of the size you want, that should be all that's required.
I haven't worked with this filter yet, so I could be incorrect about this.
PostPosted: Fri Nov 06, 2015 12:59 am  (#3)
Yes, you can control the dimensions if you assemble the montage within the GIMP program. I should have mentioned that I'm working from the command line. I use this command:
gmic *jpg -gimp_montage 4,\""V(H(0,1),H(2,V(3,4)))"\",1,1.0,0,5,0,0,0,255,0,0,0,0,0 -o output."$(date)".jpg
So I guess I'm looking for a Gimp command to create a canvas of a certain size, and then use the G'mic command in conjunction with it.
PostPosted: Fri Nov 06, 2015 4:39 pm  (#4)
I tried the following command with the gimp-canvas filter:
gmic *jpg -gimp_canvas 1600x900 -gimp_montage 4,\""V(H(0,1),H(2,V(3,4)))"\",1,1.0,0,5,0,0,0,255,0,0,0,0,0 -o output."$(date)".jpg
But it returned the error:
[gmic]-42./ *** Error *** Command '-gimp_canvas': Undefined argument '$4', in expression '$4' (for 1 argument specified).
[gmic] Command '-gimp_canvas' has the following description:
[gmic] Command 'gimp_canvas' has no description (did you mean '-gimp_lava' ?). Try 'gmic -h' for global help.
PostPosted: Fri Nov 06, 2015 11:28 pm  (#5)
Sorry Serche, but I haven't used the command line for anything as of yet. So I really can't give you any suggestions on it's use or a command that might work.
PostPosted: Sat Nov 07, 2015 6:31 am  (#6)
Only ones I can see is to make it vertical or horizontal. Scaled or aligned. You may be able in the custom field.
If it is too big you may have to scale it still
If no one answers your question here try asking it at this link https://discuss.pixls.us/
PostPosted: Sat Nov 07, 2015 9:05 pm  (#7)
Okay thanks! It may not be possible to do what I want. I will check out the link.
PostPosted: Sun Feb 21, 2016 5:12 am  (#8)
Yeah, I get this error too. Any one figured out a way to make this work?
PostPosted: Mon Feb 22, 2016 2:20 am  (#9)
If you want to do the montage for you screen dimensions....since I don't know how to do custom I would .. 1. get all pictures that you want. 2. ask for it to be horizontally arrayed (assuming your screen is horizontal) make sure it is larger than your screen, then scale it to size. You could even do it a little smaller and stretch to screen if you are using as a desktop picture.
Just looking at it again. In
Auto montage the Estimated size is 100% x 100%
custom montage is 150% x 175%
Merging mode - Aligned is 200% x 300%
Scaled is smaller
This is without padding, borders or angles of pictures.
PostPosted: Mon Feb 22, 2016 3:13 am  (#10)
See if you find an answer here. If not you may have to wait for some professional help.
viewtopic.php?f=28&t=10342&hilit=new+filter+montage
