It is currently Mon Aug 17, 2026 2:10 am
 Post subject: Potential use of G'MIC for grading video image sequences ?
PostPosted: Sat Jan 09, 2016 11:21 am  (#1)
Hi,
I only just discovered G'MIC today by chance when I was doing some searches on skin color grading/toning with RGB curves, which in turn led me to Pat Davids blog page - "Getting Around In Gimp". My main interest would be in the potential use of G'MIC for grading of video.
I have Gimp 2.8.14 and the G'MIC plugin (1.6.2.0) installed on Kubuntu 15.10 (AMD 64). I wondered if it might be possible to batch process G'MIC-transformed image sequences via the BIMP (1.16) batch manipulation plug-in, but it would appear not - G'MIC is not one of the available 'filter sets'. Something for the BIMP developer to consider maybe? I read also that work is in progress to integrate G'MIC in Flowblade and Natron, which is something to look forward to.
Meanwhile, is there any open-source (linux or windows) imaging software out there capable of doing this at this time?
Thanks.
 Post subject: Re: Potential use of G'MIC for grading video image sequences ?
PostPosted: Sat Jan 09, 2016 11:30 am  (#2)
If you have several images to process with the same G'MIC filter, it should be easy to use the command-line tool instead of BIMP.
It is the most powerful interface of G'MIC so far, and this is probably something it can do easily.
PostPosted: Sat Jan 09, 2016 12:25 pm  (#3)
OK, thanks. CLI's are not really my forte, but I'll give it a go. Before I delve into that, will it be possible to pull in the Film Emulations that way?
Cheers.
PostPosted: Fri Jun 10, 2016 12:53 am  (#4)
Inapickle wrote:
...I read also that work is in progress to integrate G'MIC in Flowblade and Natron, which is something to look forward to...
Flowblade 1.6 video editor now includes a version of G'MIC.
No Windows and OS X versions of Flowblade.
