It is currently Sun Nov 29, 2026 6:03 pm
 Post subject: BIMPing GMIC film emulations produces solid grey image
PostPosted: Thu Mar 17, 2016 1:19 pm  (#1)
Hi, friends. First time posting because this is the first time in a couple years of use that I've had a real problem with a GIMP function.
I have previously used BIMP to run GMIC film emulation effects (the Pat David film curves) in batches without incident. However I recently had to wipe and reinstall all the programs on my hard drive to fix an unrelated problem. Since reinstalling BIMP and GMIC, everything seems to run fine EXCEPT THAT any time I try to use BIMP to run a GMIC film emulation function, the output images come out as just a solid grey (as attached). I get a folder full of identical, solid grey pictures.
I'm reasonably confident that I am inputting the BIMP commands properly because I have tried using saved BIMP presets for film emulation functions that I have previously used successfully before I had to reinstall. I am able to BIMP other GMIC actions and get the proper output, just not the film emulation ones, which unfortunately are the only reason I ever downloaded GMIC in the first place. :(
Can anyone help? I'm going to go crazy over this!!
 Post subject: Re: BIMPing GMIC film emulations produces solid grey image
PostPosted: Thu Mar 17, 2016 2:56 pm  (#2)
What kind of system and versions?
For me to Win (Gimp 2.8.16 and BIMP 1.6) are working properly.
Is the preview mode (single picture *.jpg or *.png) you have a good result?
For example (film_60's):
-gimp_emulate_film_various_preview 1,1,0,1,0,0,0,0,0
- whether with this code also an error?
