It is currently Sun Nov 29, 2026 5:04 pm
 Post subject: Textured Glass
PostPosted: Wed Mar 23, 2016 12:50 am  (#1)
Whenever I use the textured glass preset it doesn't save. In fact the image is blank after it has been saved (as a png)? Is there something else I need to do.
I thought the 'glass frame' script from dinasset would also use this but it is saving :gaah. So am I doing something wrong or?
 Post subject: Re: Textured Glass
PostPosted: Wed Mar 23, 2016 1:11 am  (#2)
I did a quick test now, for me it works (Gimp 2.8.16 and G'MIC 1.6.9)
original
500_F_96230118_y5CuhJzAzdPXn27ZcgUinx8v8ZMwrx8f.jpg [ 169.62 KiB | Viewed 5770 times ]
texturized (default parms)
PostPosted: Wed Mar 23, 2016 1:15 am  (#3)
done another test in colours (I don't post the original, it's my commonly shown red rose)
PostPosted: Wed Mar 23, 2016 1:22 am  (#4)
Lovely. I currently use the G'MIC 1.6.8
I can update it but doesn't your script use the filter from G'MIC?
PostPosted: Wed Mar 23, 2016 1:23 am  (#5)
yes, it does
PostPosted: Wed Mar 23, 2016 1:26 am  (#6)
here it is
PostPosted: Wed Mar 23, 2016 1:39 am  (#7)
A (probably useless) warning: the filter DOES NOT TEXTURIZE A TOTALLY TRANSPARENT AREA.
Thus, if you make a selection and the current selection is the transparent area, not texturize occurs
the centre is shown black but it's a transparent area selected
PostPosted: Wed Mar 23, 2016 1:42 am  (#8)
NEITHER IT DOES OVER A TOTALLY WHITE AREA
PostPosted: Wed Mar 23, 2016 1:44 am  (#9)
...NOR ON A TOTALLY BLACK AREA
PostPosted: Wed Mar 23, 2016 2:05 am  (#10)
MORE IN GENERAL: THE FILTER DOES NOT GENERATE A TEXTURIZED PATTERN ON ANY FULLY UNIFORM BASE;
was this the case, Sallyanne? did you try to texturize a uniformely coloured area?
PostPosted: Wed Mar 23, 2016 2:14 am  (#11)
Thank you Dinasset, you did a very useful research. :tyspin
PostPosted: Wed Mar 23, 2016 3:13 am  (#12)
I tried it on the blue/green image after I overlayed with a transparent layer, coloured with a gradient and reduced opacity. It generated but didn't save.
PostPosted: Wed Mar 23, 2016 3:35 am  (#13)
Flattened the image and it worked
PostPosted: Wed Mar 23, 2016 7:59 am  (#14)
nice result, Sallyanne !
PostPosted: Fri Mar 25, 2016 2:54 am  (#15)
Thanks. I tried to do this earlier on the circle art but couldn't. But the glass frame script work (Go figure!)
cron
