It is currently Sun Nov 29, 2026 5:15 pm
 Post subject: Summer Shower
PostPosted: Thu Mar 24, 2016 12:21 am  (#1)
Using a photo of a spring shot and using G'MIC, I put rain and a rainbow in it. Probably doesn't look very convincing, but I tried.
 Post subject: Re: Summer Shower
PostPosted: Thu Mar 24, 2016 1:09 am  (#2)
I think the rainbow and the blue sky gives away any attempt at making it seem real.
Also the "rain", looks more like snow then it does rain.
I don't intend to be over critical toward your work. I'm only pointing out what I see, as I view it.
PostPosted: Thu Mar 24, 2016 2:09 am  (#3)
Sallyanne, if you set the rainbow behind the buildings (just on the sky) it will certainly look more realistic.
The image is nice, it's worth an attempt...
PostPosted: Thu Mar 24, 2016 3:35 am  (#4)
Ok, using a mask I put the rainbow behind the buildings, made the 'rain' less opaque and darkened the sky.
The ground isn't wet because it has just started ;)
Don't know about you but I cannot see the image I just uploaded
Should be here https://www.flickr.com/photos/115367823 ... 2/sizes/k/
PostPosted: Thu Mar 24, 2016 3:40 am  (#5)
that's nice, I guess you may put the rain more visible (just a little) and blur the rainbow (on the borders)
PostPosted: Thu Mar 24, 2016 4:05 am  (#6)
If you look at the full size picture you will see it.
PostPosted: Thu Mar 24, 2016 4:09 am  (#7)
Yes, I see the rain, but IMO (as opposed to Wallace's opinion...) rain should be more visible....
more or less as you did in the first picture
PostPosted: Thu Mar 24, 2016 5:42 am  (#8)
this is what I had in mind (my taste)
you may do it better
