It is currently Sun Nov 29, 2026 4:27 pm
Post new topic Reply to topic  [ 43 posts ]  Go to page 1, 2, 3  Next
 Post subject: Release of G'MIC 1.7.0
PostPosted: Fri Mar 25, 2016 6:14 am  (#1)
Hello there,
For information, I've just released a major version 1.7.0 of the G'MIC image processing framework (including the plug-in for GIMP).
You can get the full binaries here : http://gmic.eu/download.shtml
If you want the plug-in only : http://gmic.eu/gimp.shtml
and if you are interested by the Changelog : https://discuss.pixls.us/t/release-of-gmic-1-7-0
I hope everything will run smoothly for you if you do the update :)
Enjoy !
 Post subject: Re: Release of G'MIC 1.7.0
PostPosted: Fri Mar 25, 2016 6:38 am  (#2)
thanks, David
PostPosted: Fri Mar 25, 2016 6:47 am  (#3)
:coolthup :tyspin
PostPosted: Fri Mar 25, 2016 8:24 am  (#4)
Works excellent David. Thanks! :)
PostPosted: Fri Mar 25, 2016 12:28 pm  (#5)
Just installed the update; works well with the presets that I've tested it on. Thanks for the update, David. :)
PostPosted: Fri Mar 25, 2016 1:00 pm  (#6)
Thank you so much David. Excellent work. :tyspin
PostPosted: Sat Mar 26, 2016 1:51 am  (#7)
tried the new filter for smoothing; it took 3 minutes on an image 2560x1440.
Is this the normally expected time for a quite good PC (I5, with SSD primary disk, 8GBRam)?
I used defaults.
If so, it is one of those perls which can be used very rarely, when all other smoothing tools have failed.
PostPosted: Sat Mar 26, 2016 3:54 am  (#8)
Thank you :)
PostPosted: Sat Mar 26, 2016 4:10 am  (#9)
Thanks for all your encouragements.
@dinasset : yes, this new denoising tool is particularly slow to compute. It does extremely sophisticated operations for each image pixels. On the other hand, it happens that it performs really well (way better than the other denoising algorithms we already had before).
PostPosted: Sat Mar 26, 2016 4:25 am  (#10)
yes, I've seen, and I'll use it when needed, thanks a lot!
PostPosted: Sat Mar 26, 2016 2:00 pm  (#11)
Image Thanks David, love the Multi-scale Operator.
PostPosted: Sun Mar 27, 2016 10:02 pm  (#12)
:yes my gimp/G'MIC starts up without throwing an error now. Did the last couple oftimes on start up but still worked. Thank you David :)
PostPosted: Sun Mar 27, 2016 10:17 pm  (#13)
Kimba wrote:
[ Image ] Thanks David, love the Multi-scale Operator.
Yeah; like this preset too, Kimba. Still hoping David will add a rotational option to it (each layer will rotate to a chosen angle; default 0 degs of course).
Below's my motivation for the varying angle (15deg increments in this case). Also, it would be nice if layers would output smallest to largest; the default's the opposite which means I have to reverse the layer order. Yes; asketh for too mucheth. lol
PostPosted: Sun Mar 27, 2016 11:14 pm  (#14)
Nice Lyle.
PostPosted: Mon Mar 28, 2016 2:47 am  (#15)
Kimba - thanks for the heads up; just had a quick play and this is going to be a lot of fun; easy instant glass butterfly ...
PostPosted: Mon Mar 28, 2016 7:10 am  (#16)
Thank you David,
The new noise filter is excellent, as far as I can see. I tested it on small images, but with my computer, I now think I live in stone Age. :bigthup
PostPosted: Mon Mar 28, 2016 11:05 am  (#17)
One of my brushes with this filter.
PostPosted: Mon Mar 28, 2016 2:09 pm  (#18)
Very nice, Sallyanne. Lovely, OMG.
PostPosted: Tue Mar 29, 2016 7:54 am  (#19)
Tried this with my red hibiscus
PostPosted: Tue Mar 29, 2016 8:14 am  (#20)
Very nice results everyone
