It is currently Sat Nov 28, 2026 2:59 pm
 Post subject: Release of G'MIC 1.7.1
PostPosted: Mon Apr 25, 2016 1:52 pm  (#1)
Hello friends,
There is a new release (numbered 1.7.1) of the G'MIC image processing framework, that has been made available today !
This is a minor release somehow: It has several improvements and new filters, but most new features have been already backported for the users of the previous major version (1.7.0), thanks to the nice filter update mechanism we have in G'MIC.
The Changelog is available here : https://discuss.pixls.us/t/release-of-gmic-1-7-1/
It shows the amount of work that has been done since then. I hope you'll keep enjoying G'MIC as much as I enjoyed working on it (for almost the last 8 years!).
 Post subject: Re: Release of G'MIC 1.7.1
PostPosted: Mon Apr 25, 2016 2:30 pm  (#2)
Thanks for the heads up, David. I've been toying with a new rendering technique that uses a blend of Engrave with the original image followed by Segmentation for a camouflage like painting result. Add Bilateral filter and few other presets (for cleanup and anti-alias) and you get the type of rendering below (posted elsewhere here already; just one of the many captures I took at the George Renaissance Festival this past weekend). :)
PostPosted: Mon Apr 25, 2016 4:22 pm  (#3)
Thanks for all your hard work. Appreciate it very much.
PostPosted: Mon Apr 25, 2016 5:16 pm  (#4)
David, great to see the new release. I'll have to remember if I installed 1.7.0 :oops:
On the -img2hex & -hex2img commands added to 1.7.1, can you define what a hex string looks like from G'MIC's point of view? Or just point me to any link that explains it.
Souphead.
PostPosted: Mon Apr 25, 2016 8:46 pm  (#5)
This has not happened to me before.
I have deleted the G'MIC I had so I could go ahead and install this one. Windows won't let me though, even when I try to run as administrator! :hoh
Whoohoo it is finally installed :yes Found out where I could 'run any way'. Didn't see the option before. :oops:
Now to have a look and play with my new toy.
PostPosted: Tue Apr 26, 2016 1:12 am  (#6)
Souphead.
Yes, for instance, with a test image you get :
$ gmic -testimage2d 16 -e \$\{-img2hex}
gives you :
[gmic]-0./ Start G'MIC interpreter.
[gmic]-0./ Input 2d synthetic image of size 16x16x3.
[gmic]-1./ 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
[gmic]-1./ Display image [0] = '[2d test image]'.
PostPosted: Tue Apr 26, 2016 7:35 am  (#7)
I get this below and it displays the testimage2d image in a separate window:-
This is the Windows GMIC and is 1.7.1
Souphead
PostPosted: Tue Apr 26, 2016 7:53 am  (#8)
Ha you are on Windows...
I'm not familiar with the use of the Windows console, but maybe try to remove the backslash, so ${} instead of \$\{\}.
PostPosted: Tue Apr 26, 2016 9:30 am  (#9)
Yep, that was it, no escapes needed.
PostPosted: Tue Apr 26, 2016 11:43 am  (#10)
Runounours, that seems amazing.
Asking bashfully.... I'm on a Mac and my last working G'mic (v. 1.6.5) was on Gimp's v. 2.8.14 both working well on OSX El Capitan. Recently, foolishly, I installed Gimp's 2.8.16 and there doesn't seem to be a working G'mic for this version on a Mac. Why would I do that? Long story...but, would you know if someone is working on a possibility for us Mac folk on El Capitan. I believe I'm not alone - there was another recently having difficulties.
McGimp 2.8.14
G'mic 1.6.5
PostPosted: Tue Apr 26, 2016 11:55 am  (#11)
Dalia, you may find information here : viewtopic.php?f=28&t=13169
I can't help much more as I don't have a Mac (and I'll probably never have one).
Installing G'MIC on Mac has always been a bit of a mess, so I'm not surprised :)
PostPosted: Tue Apr 26, 2016 2:33 pm  (#12)
For your answer alone Runounours, I'm thankful! :tyspin
McGimp 2.8.14
G'mic 1.6.5
PostPosted: Tue Apr 26, 2016 9:09 pm  (#13)
OK so if I understand correctly, I would get this by clicking the download new updates in Gmic?
PostPosted: Sun May 08, 2016 2:39 pm  (#14)
Dalia, there is now a 1.7.1 gmic build unluckily still only for Gimp 2.8.14 running on El Capitan too from GIMPonOSX.
This nice Mac build of Gimp 2.8.16 on the Gimp download page does not have any plugins. Maybe you try to convince the Gimp builders to prepare a richer Mac bundle with gmic!?!
PostPosted: Mon May 09, 2016 2:28 pm  (#15)
Lylejk, I didn't know we were at least vaguely neighbors. How often do you get to the Georgia Renaissance Festival?
PostPosted: Tue May 10, 2016 1:26 am  (#16)
Hello, I want to report that Norton 360 finds a malicious file in new G'MIC(1.7.1), via "heuristic detection".
That file is called "SAPE.Heur.AF456". Norton says the risk is high.
In Norton, there is a link which leads to page of this virus but that page is "Not Found"
( lol I can't send the link because my post looks too spammy for a new user )
But there is a somewhat similar thing called "W32.SAPE.Heur.2" if you want to check it out.
PostPosted: Tue May 10, 2016 1:43 am  (#17)
It's more then likely a False Positive.
