It is currently Sat Nov 28, 2026 1:11 pm
Post new topic Reply to topic  [ 63 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: Release of G'MIC 1.7.2
PostPosted: Mon May 30, 2016 7:12 am  (#1)
Hello GimpChat friends !
I'm happy to announce the release of a new version 1.7.2 of the G'MIC image processing framework (including the plug-in for GIMP).
It is recommended to update your installation to this newest version as soon as possible, since some important changes and optimizations have been introduced in the G'MIC core that break the compatibility of the filter definitions with the previous versions (so, new filter updates will be available only for version >1.7.2 from now!).
The full Changelog can be found here : https://discuss.pixls.us/t/release-of-gmic-1-7-2
There is particularly a bunch of new color presets that can give different looks to your images, as shown below:
I hope you'll enjoy this new version ! Work is going on to offer you the best possible plug-in for GIMP :keybdtype :sleepkbd :hehe !!
 Post subject: Re: Release of G'MIC 1.7.2
PostPosted: Mon May 30, 2016 7:34 am  (#2)
Just installed it; thanks for the head's up, David. :)
PostPosted: Mon May 30, 2016 8:07 am  (#3)
David,
Thank you very much again.
PostPosted: Mon May 30, 2016 8:42 am  (#4)
:coolthup :tyspin
PostPosted: Mon May 30, 2016 8:45 am  (#5)
By coincidence, I have to report that "HSL adjustment" filter doesn't work properly in G'MIC 1.7.2:
It does work in 1.7.1 pre.
It is a bit pity, because I made just publicity for this awesome filter. See "Repairing Color Cast"
(windows 64)
PostPosted: Mon May 30, 2016 9:03 am  (#6)
In both cases I used "auto reduce level" and "auto set hue inverse". With both all the sliders in neutral
To steven8: I did use your photo of "repair color cast" to show mister Tschumperlé something that was wrong. now this problem is solved, so I delete the images here. Thank you steven8.
PostPosted: Mon May 30, 2016 9:17 am  (#7)
Thanks for the feedback iarga, indeed there was a little bug remaining.
I've just solved it, and if you refresh your filters (press the 'update' button), the HSL adjustment filter should work again !
Thanks for reporting !
PostPosted: Mon May 30, 2016 9:22 am  (#8)
It is solved, thank you for your quick reaction. (again ;) )
PostPosted: Mon May 30, 2016 9:40 am  (#9)
Thanks so much David! :jumpclap
PostPosted: Mon May 30, 2016 12:27 pm  (#10)
David, thanks for removing another color related issue, before even asking you. Thats realy fast.
:ninja
PostPosted: Mon May 30, 2016 12:44 pm  (#11)
However another one: The "Color grading"-filter doesn't work anymore:
after "OK":
PostPosted: Mon May 30, 2016 12:55 pm  (#12)
That is right iarga, thanks for noticing this one too !
Should be fixed now as well :)
PostPosted: Mon May 30, 2016 1:12 pm  (#13)
It doesnt give an error now, but the "color grading" does not work properly. The specific colorgrade sliders for highlights and shadows do nothing, only the sliders for the midtones do work. (with color grading on)
PostPosted: Mon May 30, 2016 1:40 pm  (#14)
Ah yes, sorry. Thanks a lot for all your tests iarga, that is really useful !
This should be fixed now.
PostPosted: Mon May 30, 2016 1:56 pm  (#15)
I think it works like it did before. Thank you. I know there are 465 filters in G'MIC. You said a lot changed under the hood. So with changing complex stuff, this kind of things can happen I suppose.
PostPosted: Mon May 30, 2016 1:57 pm  (#16)
Yes, and I cannot thank enough people who help finding this kind of hidden bugs.
So, thanks again :)
PostPosted: Mon May 30, 2016 2:01 pm  (#17)
I didn't test your pre-release of 1.7.2, so next time I will try to do some testing beforehand.
PostPosted: Mon May 30, 2016 2:33 pm  (#18)
A lot of filters under stereoscopic 3d give an error, this is one example:
After "OK":
PostPosted: Mon May 30, 2016 3:24 pm  (#19)
Ah I see, yes.
And does it work now, after an update ?
PostPosted: Mon May 30, 2016 3:32 pm  (#20)
Yes it does work now, thank you.
This was the last one, today. :hehe
