It is currently Sat Nov 28, 2026 12:50 pm
 Post subject: G'Mic Inkwash
PostPosted: Sat Jun 18, 2016 1:29 pm  (#1)
GIMP Version: 2.8.14
Operating System: Mac OS
OS Version: Mavs
GIMP Experience: Basic Level
List any relevant plug-ins or scripts:
G'Mic Inkwash
Great results with low resolution however unable to get similar results on larger images.
I need to use large images for printing on large paper and can't get acceptable results. Does anyone here have experience with the control sliders for Inkwash on large images?
File comment: 640 480 / 4000 3000
 Post subject: Re: G'Mic Inkwash
PostPosted: Wed Jul 06, 2016 12:05 pm  (#2)
It will do it's thing for the larger image. But if you want the same results for a larger image as smaller you may have to change the settings to match otherwise you may not even see any effects at all.
I used the same size image here and cropped it to about 2900 square
First one I did with default settings and the second one I did with double settings and with manual settings
PostPosted: Thu Jul 07, 2016 4:47 pm  (#3)
Very cool filter! Two easy steps create a very painterly look. Thanks for pointing this one out.
