It is currently Sat Nov 28, 2026 12:39 pm
 Post subject: Release of G'MIC 1.7.3
PostPosted: Mon Jun 20, 2016 10:16 am  (#1)
Hello friends,
A new (minor) version (numbered 1.7.3) of G'MIC has been released today.
See the Changelog here : https://discuss.pixls.us/t/release-of-gmic-1-7-3
Have a nice day ! :)
 Post subject: Re: Release of G'MIC 1.7.3
PostPosted: Mon Jun 20, 2016 4:14 pm  (#2)
Degradations / Pixel sort, looks interesting.
PostPosted: Mon Jun 20, 2016 4:28 pm  (#3)
:coolthup
PostPosted: Mon Jun 20, 2016 10:10 pm  (#4)
Should I uninstall the older version of GIMP before installing the newest one? I am pretty new to using it and with software of this type. This forum seems very helpful so far, so I registered an account.
PostPosted: Mon Jun 20, 2016 11:12 pm  (#5)
Hi Rocque and welcome to Gimp Chat.
As for your inquire regarding uninstalling a previous version of G'MIC.
I'm a windows 10 64bit user and I do not uninstall the old version,
when installing a new version of G"MIC.
However,
uninstalling the old version then installing the latest version of G'MIC will also work.
One reason you might wish to uninstall the old version.
Would be if it was not functioning.
PostPosted: Tue Jun 21, 2016 5:44 am  (#6)
PClinuxOS - Gimp 2.8.16 - G'mic 1.7.3 linux 32 bit
What has happened to the interactive color curves?
I can see Curves moved to Testing -> Ronounours and while lots of sliders are fine, can't beat a curve to drag around.
PostPosted: Tue Jun 21, 2016 6:07 am  (#7)
It is now "Curves" Colors>Curves
I had to search too.
PostPosted: Tue Jun 21, 2016 6:10 am  (#8)
got it. thanks
PostPosted: Fri Jun 24, 2016 12:50 pm  (#9)
error on filter High Pass with contrast>5
PostPosted: Sat Jun 25, 2016 9:47 am  (#10)
another info:
under gmic.eu the download page for the plug-in has an empty .exe for 32-bits (need to use the .zip)
PostPosted: Sat Jun 25, 2016 12:28 pm  (#11)
Thanks dinasset, both issues should be fixed now.
PostPosted: Sat Jun 25, 2016 1:43 pm  (#12)
thanks to you David !
PostPosted: Sun Jun 26, 2016 9:52 pm  (#13)
Does anyone know how my faves file doesn't appear to exist, yet I have faves in Gmic. I have been searching as I wanted to backup faves before inserting the new Gmic.
PostPosted: Sun Jun 26, 2016 9:55 pm  (#14)
I would like to know how to remove one of my favs headings? I ended up with two, I must have clicked something.
PostPosted: Sun Jun 26, 2016 10:37 pm  (#15)
Look here 2-ton!
File comment: Example image...
PostPosted: Mon Jun 27, 2016 8:10 pm  (#16)
Yay, thank you for the info! I had several of the 'update info's and wanted to get rid of them, and your instructions worked like a charm.
PostPosted: Tue Jun 28, 2016 4:10 am  (#17)
:coolthup
PostPosted: Tue Jun 28, 2016 10:05 am  (#18)
Now if I can just get some spare time and update my McGimp and G'Mic! I don't want to do it until I have a whole free day because I just know I'll have issues that will take time to figure out.
PostPosted: Tue Jun 28, 2016 3:25 pm  (#19)
Use The Power of Positive Thinking 2-ton.
If that doesn't work,
use The Force
PostPosted: Tue Jun 28, 2016 4:42 pm  (#20)
Found my faves file in .config under gimp_faves. I get gmic I think from the ppa that updates gimp so that probably explains it.
