It is currently Mon Aug 10, 2026 3:11 pm
 Post subject: G'MIC
PostPosted: Fri Apr 01, 2011 1:56 pm  (#1)
I know this is probably a stupid question, but, can I use G'MIC on Windows 2000 ? and what is it for anyway, a plug-in thing ?
Thank you my gurus :tyspin
~diane
 Post subject: Re: G'MIC
PostPosted: Fri Apr 01, 2011 2:56 pm  (#2)
Yeah it is a Plug-in thing... I honestly don't know how to describe it.
And why are you using Windows 2000? And I have no idea if it would work
I'm back I think
PostPosted: Fri Apr 01, 2011 6:19 pm  (#3)
~diane
Yes it will run on Windows 2000.
More Info - http://gmic.sourceforge.net/
Just download the executable and install into your user/gimp-2.6/plug-ins folder (G'MIC) will probably set that as default anyway.Restart Gimp.It will be found under Filters/G"MIC.
G'MIC stands for GREYC's Magic Image Converter and has currently 288 filters available within it. :)
It's a very nice addition to anyones Gimp install.
Welcome to Gimp Chat by the way Diane!
PostPosted: Fri Apr 01, 2011 7:02 pm  (#4)
This has me wondering though, does she have enough RAM to help the plug-in function in the capacity she needs it to?
I'm a bit skeptical it will run as smoothly for her as it does with anyone else running dual cores with mega RAM.
Diane, if you get it installed and running, could you post back your experiences with running G'MIC?
PostPosted: Fri Apr 01, 2011 7:05 pm  (#5)
I only have 512mb RAM with 1 core, so i think it will be okay for her.It runs great for me. :)
PostPosted: Fri Apr 01, 2011 7:21 pm  (#6)
What OS are you using for that system, Rod?
PostPosted: Fri Apr 01, 2011 7:25 pm  (#7)
Windows XP
PostPosted: Fri Apr 01, 2011 11:41 pm  (#8)
I misspoke here, I am using windows xp (not windows 2000) and I have 2 GB RAM (and a dual core processor).....I was distracted when I wrote the initial computer info. lol......I will give it a try and see what happens....Still trying to learn this and sort things out. Thank you again my gurus.....I appreciate your time and assistance :)
~diane
PostPosted: Sat Apr 02, 2011 7:58 am  (#9)
~diane
Oh you shouldn't have any problems running G'MIC then. :)
Have fun with it.
