It is currently Wed Nov 25, 2026 6:43 pm
 Post subject: GMIC GIMP Plug-in suggestion: Search for filter
PostPosted: Tue Nov 08, 2016 8:30 pm  (#1)
I read the GMIC README and I hope I have the right place to make a GMIC GIMP Plug-in suggestion.
When the GMIC GIMP Plug-in is open, at the bottom of available filters, there are a couple of controls (add to favorite, update, internet, and expand/collapse). It would be very nice addition if there was a search --- either at the bottom of the list or at the top. As I go through tutorials and such, I'm finding I'm scrolling up/down, expanding/collapsing trying to find a particular filter.
I'm not sure when they were added, but the links to videos is a nice feature (i.e., Frequencies -> Fourier transform).
 Post subject: Re: GMIC GIMP Plug-in suggestion: Search for filter
PostPosted: Tue Nov 08, 2016 9:03 pm  (#2)
Welcome to GIMPCHAT.
Maybe this is what you are looking for - GMIC search of filters already exists ...
PostPosted: Wed Nov 09, 2016 4:45 am  (#3)
Wow... that was quick :-) I totally missed that in the About section. Not what I envisioned (it's better), but totally solves the problem. A real time saver. It looks a little weird at first. The text box says 811 found and then shows lines & lines of html entities, but you can scroll past them. And the search/find works like a champ. Typed in fourier and it shows that it is in the Frequencies section. Yeh! Thank you.
Snippet:
Initial display of "Search Filters":
パターン / 迷彩-
PostPosted: Wed Nov 09, 2016 6:58 am  (#4)
I also wrote a script that loads the G'MIC filter page as it updates with new filters. This list shows where certain filters are located in G'MIC's menu tree.
Opening /clicking on the filter in GIMP opens this webpage dynamically in your default browser window.
http://gmic.eu/gimp_filters.txt
Script can be found in the menu under Image window "G'MIC>Help>GMIC Filter Webpage"
links-script-fu_RD.scm [1.54 KiB]
Downloaded 282 times
Place in your scripts folder and either restart GIMP or go to Filters>Script-Fu>Refresh Scripts
 Post subject: Search for filter is missing under About
PostPosted: Sat Apr 21, 2018 1:26 am  (#5)
The Search Filter is gone under About. I thought I could live without it, but I can't :-)
Gimp 2.8.22
gmic 2.2.1
LM 17.3/kde
PostPosted: Sat Apr 21, 2018 2:14 am  (#6)
There has been a search filter in the plug-in since a while now, but you have to use the Qt version of the G'MIC plug-in,
instead of the GTK one (which is **not** maintained anymore!).
See screenshot below.
PostPosted: Sat Apr 21, 2018 4:02 am  (#7)
I think the problem is Linux Mint 17 is based on Ubuntu 14.04 – Trusty (Thar) and AFAIK the QT requirements are not supported. However the GTK version works fine.
Only a suggestion but there is a list of (most) filters https://gmic.eu/gimp_filters.txt
A bit tedious but open that in a text editor and do a search to find the path.
