It is currently Fri Nov 27, 2026 2:09 am
 Post subject: Previous versions of G'MIC
PostPosted: Mon Jun 12, 2017 8:12 pm  (#1)
GIMP Version: 2.8.22
Operating System: Windows
GIMP Experience: Basic Level
I need G'MIC 1.79 to use with SpiderPaint. The setup file that I had no longer works and something disrupted the one I was using. Where can I obtain the older version? On the website only the new and current ones are listed.
 Post subject: Re: Previous versions of G'MIC
PostPosted: Mon Jun 12, 2017 10:15 pm  (#2)
Pat - which Windows ... 32 bit or 64 bit; also does it have to be GMIC 1.7.9 as I have tripped through my back up files and found a version of GMIC 1.7.8 for win64.
PostPosted: Mon Jun 12, 2017 10:49 pm  (#3)
@Pat
G'MIC/Windows Files
PostPosted: Tue Jun 13, 2017 5:53 pm  (#4)
Thank you very much, OMG for looking for the script.
RMDESIGNS, thank you also, I didn't know there was an index of G'MIC scripts. Good to know! I found the one I needed. Thanks again.
