Hello there,
Just a word about a new filter I've just included in the today's prerelease of G'MIC (numbered
2.0.2_pre), located at
Artistic / Quadtree variations.
I'm pretty sure you, filters guys, will know what to do with it
Preliminary note: This filter is available
only if you have installed the very latest pre-release version (
2.0.2_pre) of the G'MIC plug-in for GIMP. And even with that installed, you'll have probably to press the
Update filter button to make the filter appear. That's very recent work
So, what does the filter do ?
Mainly, it decomposes an image using a quadtree technique (see
https://en.wikipedia.org/wiki/Quadtree), then uses the quadtree information to resynthetize an image with different types of possible rendering. For instance, if you start with this image:
A quadtree-based decomposition will basically looks like this
which means the filter tries to recognize which parts of the images are the most important to consider (i.e. contains the more information, like contours, textures, etc.).
If you re-use these geometric information to draw brush strokes, you can end up with some nice painting effects :
is transformed as
and
is transformed as
I'd be curious by what you can get with this filter. Do not hesitate to test and tell me !
Here is a final screenshot of the filter in action :
