It is currently Wed Nov 25, 2026 11:19 pm
 Post subject: Unable to Update G'Mic
PostPosted: Sun Jul 30, 2017 12:09 pm  (#1)
GIMP Version: 2.8.22
Operating System: Windows
OS Version: 64 bit
List any relevant plug-ins or scripts:
G'MIC
I have been trying to update G'MIC on my windows 10 64-bit machine for several weeks. When I tried and do it through the G'MIC plugin in my Gimp program, the link leads to a 404 error page. When I use the web address, I am able to download the update file.
A few weeks ago when I ran the update exe file it froze my system. I was able to recover after a few minutes.
I just tried again. I again got the 404 message when clicking the link in G'MIC in Gimp. I went to the website using the first part of the link in my G'MIC in gimp- http://gmic.eu/ . I went to the downloads page, and downloaded the version for windows 64-bit. When I run the setup it seems to work correctly. When I try to open gimp, I get the following error-" the procedure entry point pthread_setname_np could not be located in the dynamic link library." Under that "C:\Users\grits\.gimp-2.8\plug-ins\libglib-2.0-0.dll."
I get that twice, then Gimp opens. I then try and open G'MIC. I get that same error message.Then I get an error that the "Plug-in crashed: "gmic_gimp.exe"" and I may want to save and restart Gimp.
I did look at the gimp download site beforehand and my version number matched the latest there.
Edit- After posting this I did reinstall to the latest stable version of gimp from gimp.org. It didn't change anything.
Edit2: There is a version of the libglib-2.0-0.dll file in my plugins folder, dated 10/13/2016.
Thanks for any help.
 Post subject: Re: Unable to Update G'Mic
PostPosted: Sun Jul 30, 2017 9:07 pm  (#2)
Have you got the latest QT version. You will need that to be able to update.
PostPosted: Sun Jul 30, 2017 11:44 pm  (#3)
What is a QT version?
PostPosted: Tue Aug 01, 2017 11:46 pm  (#4)
This is what I installed- gmic_gimp_qt_win64
I picked: G'MIC plug-in for GIMP (2.8+), Windows 64 bits: installer
I clicked Latest stable version: 2.02 (above that text) beforehand.
Can anyone tell me how to resolve this?
Thank you
PostPosted: Wed Aug 02, 2017 12:37 am  (#5)
Try uninstalling G'MIC, then download the zip file and create a directory in your user GIMP folder, then use GIMP's interface to add a path to the G'MIC plugin. I don't like or trust installers and always use alternative ways if given them and this is both the original way to install G'MIC and my preferred way to do so. :)
PostPosted: Wed Aug 02, 2017 10:49 pm  (#6)
Problem solved. When I went in to remove the recently installed G'MIC, I found an older version was also installed. (I thought I had removed it.) I removed both versions, and since I wasn't 100% sure how to do the manual install, I took a chance and did the usual install. It's working now, thanks to you both!
PostPosted: Thu Aug 03, 2017 6:34 am  (#7)
Glad you got the problem solved. :)
PostPosted: Mon Aug 07, 2017 9:48 am  (#8)
This is good to know. I have 3 versions of G'Mic and, although I haven't gotten an error msg, I don't think it has ever actually updated.
My Sigs = My Photos
