It is currently Wed Nov 25, 2026 10:16 pm
 Post subject: Release of G'MIC 2.0.4
PostPosted: Mon Sep 18, 2017 10:35 am  (#1)
Hello folks !
A new minor version (numbered 2.0.4) of the G'MIC image processing framework has been posted today.
This new stable version stays (mostly) compatible with the previous version 2.0.3.
The full changelog can be found here : https://discuss.pixls.us/t/release-of-gmic-2-0-4
I hope you'll enjoy it !
 Post subject: Re: Release of G'MIC 2.0.4
PostPosted: Mon Sep 18, 2017 10:41 am  (#2)
:tyspin
PostPosted: Mon Sep 18, 2017 4:07 pm  (#3)
Installed 2.0.4 on Windows 7 64 bit, but when I click on the about button it still shows up as 2.0.2
My Sigs = My Photos
PostPosted: Mon Sep 18, 2017 10:29 pm  (#4)
Just got home from work (my Friday; yea). Just download and extracted the zip file where it belonged and all's well. Just tested one preset, but it worked fine. Thanks for the update, David. :)
PostPosted: Tue Sep 19, 2017 2:21 am  (#5)
What says the plug-in title bar ? The version number is displayed there.
PostPosted: Tue Sep 19, 2017 4:37 am  (#6)
Not sure what Greg's seeing, but, I'm seeing 2.04, David. :)
PostPosted: Tue Sep 19, 2017 8:52 am  (#7)
Title bar shows 2.0.2
The installer showed 2.0.4
I may try uninstalling and reinstalling.
Even to going uninstall menu shows 2.0.4
My Sigs = My Photos
PostPosted: Tue Sep 19, 2017 9:19 am  (#8)
Hello Gimp G'MIC Users
I install G'MIC 2.0.4.
It seemed to be all right.
Thanks
Doron
4X5DF.
PostPosted: Tue Sep 19, 2017 10:35 am  (#9)
The picture below is before doing the uninstall and reinstall. Doing uninstall and reinstall leaves me with no G'Mic at all. Reinstalling 2.0.2 still leaves me with no G'Mic. I even downloaded the zip version and that's a no go.
Weird problem but I'll figure it out.
My Sigs = My Photos
PostPosted: Tue Sep 19, 2017 11:11 am  (#10)
This is what I see, Greg. Don't like installers and am grateful I can just unzip (copy/paste). :)
PostPosted: Tue Sep 19, 2017 11:22 am  (#11)
Since G'MIC v.2.0.3, the default install folder is a subfolder of the GIMP plug-in folder, so you need to add this subfolder to the GIMP preferences to make it found the G'MIC plug-in.
PostPosted: Tue Sep 19, 2017 11:55 am  (#12)
Thank You Ronounours! This was the issue. I didn't see any notes pointing this out when I downloaded it.
This is something that should be put in big red,bold and underlined letters when you go to download it.
My Sigs = My Photos
PostPosted: Wed Sep 20, 2017 2:34 am  (#13)
Hello Gimp User
Did you add the new G'MIC Folder ?
I add a picture from my Gimp.
Doron
4X5DF
PostPosted: Wed Sep 20, 2017 1:42 pm  (#14)
Thank you Ronounours. Mine shows version 2.0.5.
PostPosted: Thu Sep 21, 2017 3:50 am  (#15)
@Rod: yes, I've started working on the next version 2.0.5 as well, and as it is intended to be fully compatible with 2.0.4, I'll regularly put updated pre-versions for 2.0.5 on the G'MIC website, and make them as the default download links.
PostPosted: Thu Sep 21, 2017 4:35 am  (#16)
As mentionned I had to manually create the folder for the windows 10 system. its name is "gmic_gimp_qt" in the "plug-ins" folder of the user. Then I had to install Gmic 2.04 again and it works fine ! I loose some of the favs of my Gmic but not all. Thank you for the informations. :hi5
