It is currently Wed Nov 25, 2026 7:51 pm
 Post subject: G'Mic online: Frame [blur] broken?
PostPosted: Wed Feb 21, 2018 7:03 pm  (#1)
I cannot figure out how to use the "Frame [blur]" filter of the new G'Mic online: X-centering, Y-centering and Angle don't work, the picture's always in the right upper corner, always in the same position and angle no matter in which position the sliders are.
Well, to be precise, there IS a way to position the picture as I found out by accident: with the "Shadow smoothness" slider... I'm not sure if that's intended to work that way...? All other sliders in the last part from Outline size to Angle don't have *any* effect.
In case it matters: I'm using Chromium browser on Ubuntu Linux.
 Post subject: Re: G'Mic online: Frame [blur] broken?
PostPosted: Wed Feb 21, 2018 7:52 pm  (#2)
Works fine here in Linux Mint, which is based on Ubuntu. Perhaps you updated Gmic and are still using the old filters version. You should refresh the filters by ticking the internet box, then click on the refresh button.
PostPosted: Wed Feb 21, 2018 7:57 pm  (#3)
I'm talking about the online version https://gmicol.greyc.fr !
PostPosted: Wed Feb 21, 2018 8:07 pm  (#4)
I never used the Online version. I just tried it with Chromium and can confirm your problem. I recommend you install Gmic locally on your computer.
PostPosted: Wed Feb 21, 2018 9:44 pm  (#5)
Thanks for confirming and the advice. Actually I have Gimp and use G'Mic as plugin a lot - but sometimes I am not at my PC but somewhere else ;). Is there someone who feels responsible for the online version and can fix it?
PostPosted: Thu Feb 22, 2018 5:15 am  (#6)
Thanks for noticing this, I'm trying to fix this problem !
