It is currently Wed Nov 25, 2026 5:57 pm
 Post subject: [SOLVED] How to install Gmic 2.2.3 QT on Linux64 Gimp 2.10?
PostPosted: Sun May 20, 2018 6:09 am  (#1)
Hello!
Just realized the Gmic .deb installs GTK version. Is the QT standalone .zip on the works, or is it possible to get QT some other way installed?
The file that stores favorites is different and not compatible, it's gui_faves and on Windows gmic_qt_faves.json
My goal is to get faves from the Windows Gmic QT 2.2.3 transferred somehow to Linux. This worked with 2.8 Gimp simply by copying the files over.
Thank You!
 Post subject: Re: How to install Gmic 2.2.3 QT on Linux64 Gimp 2.10?
PostPosted: Mon May 21, 2018 3:42 am  (#2)
From one of your previous posts, looks like you are using Ubuntu 18.04 I am assuming you are using the Gimp 2.10.0 from the gimp-edge ppa.
Sorry to be outspoken about this, but why do you want a deb package for gmic_gimp_qt? I can understand for an application with hundreds of files and dozens of dependencies, gimp_gmic_qt is a single 7 MB file.
Want the gmic_gimp_qt plugin. Two possible ways to go.
The Gimp 2.8 version 2.2.3 works. Get the zip from
https://gmic.eu/files/linux/gmic_gimp2. ... _amd64.zip
Unzip it, permissions are already set, put the file in your Gimp 2.10 plugins folder ~/.config/GIMP/2.10/plug-ins
proof: https://i.imgur.com/LbCZENH.jpg
I compile both the qt and gtk versions for my own use. QT version, says 2.9 is version 2.2.4 from a couple of days ago.
https://my.pcloud.com/publink/show?code ... AHlYwbWSOX
Same as before, unzip, goes in ~/.config/GIMP/2.10/plug-ins proof: https://i.imgur.com/vZ61ROG.jpg
PostPosted: Mon May 21, 2018 6:20 am  (#3)
Yeah I think I must have had cerebral short circuit or something starting to play with .deb
Had to delete all the files one by one because I installed it via software.
Got it working, thanks much rich2005! :bigthup
