It is currently Wed Nov 25, 2026 7:30 am
 Post subject: Removing background of an image using command line
PostPosted: Tue Dec 25, 2018 9:22 pm  (#1)
Hi, can you help me any one. How to remove background to using this tool. i am new of this tool and i'm try to research on the python script to remove background of an image.
Please give me some idea to remove background.
 Post subject: Re: Removing background of an image using command line
PostPosted: Wed Dec 26, 2018 4:45 am  (#2)
Command line? No idea.
You can however do foreground select using the tool in Gimp and invert the selection clearing the background (make sure your image has an alpha channel if you want a transparent background after) . Or if you have GMIC there is a similar filter called Extract foreground (Interactive). You can also do it with masks in gimp.
Edit: Also forgot about fuzzy wand selector :fuzzsel or same colour :colsel if the image you want to keep doesn't have the same colour as the background in it
PostPosted: Wed Dec 26, 2018 5:47 am  (#3)
The real question is how you identify the background color... it is given as a parameter or should it be discovered (color of the 4 corner pixels, for instance?)
