It is currently Tue Nov 24, 2026 4:49 pm
 Post subject: How to use G'MIC > Layers > Align Layers
PostPosted: Wed Jan 16, 2019 10:47 am  (#1)
I have some shots handheld and would need to align them. I have tried to use the plugin-in and with the following settings:
Alignment Type: Rigid
Smoothness: 0.3
Scales: Auto
Revert Layers: Unchecked
Input Layers: All visible
Output Mode: New Layer(s)
Preview mode: 1st output (default)
The preview looks aligned, however, after I click apply, the new layers created were exactly the same as the original image layers.
Should the plugin automatically crop and move the image in all the new layers? Did I missed out on anything?
Thanks in advance!
 Post subject: Re: How to use G'MIC > Layers > Align Layers
PostPosted: Wed Jan 16, 2019 11:09 am  (#2)
I guess that has to do with the smoothness parameter which is not working properly.
Try with a very low smoothness, and it may be OK.
That looks like a bug anyway, so I have to fix it.
PostPosted: Wed Jan 16, 2019 5:43 pm  (#3)
Thanks for the advice, I will try this again later.
May I know what will be the expected behaviour if the filter works correctly after application? For example, the layers will be aligned in GIMP layers by cropping and shifting.
PostPosted: Thu Jan 09, 2020 6:28 am  (#4)
Hi, did you resolve this issue ? I have the same problem. Preview is OK, but after i click OK, layers are same as before.
I use version 2.7.5 of this plugin.
