It is currently Wed Nov 25, 2026 5:43 am
 Post subject: 17 jan 2019 h 18.00 what happen? [SOLVED]
PostPosted: Thu Jan 17, 2019 1:03 pm  (#1)
after h18.00 (rome time) many filter dont works anymore, before at 17:00 any problems:
i presume for a definitions update.
Please fix. Tnx
Same with gmic 244
Or where found old definition for gimp filters?
 Post subject: Re: 17 jan 2019 h 18.00 what happen? filters are broken
PostPosted: Thu Jan 17, 2019 2:56 pm  (#2)
2.4.3 is still OK
PostPosted: Fri Jan 18, 2019 4:22 am  (#3)
Hello telperion, I also have this problems and reported them on pixls.us:
https://discuss.pixls.us/t/on-the-road-to-2-5-0/9413/10
made a link to this topic too.
PostPosted: Fri Jan 18, 2019 5:29 am  (#4)
tnx iarga for confirm of the problem.
more info from console log errors:
[gmic_gimp_qt]./apply/ v -99 gcd_normalize_brightness 0.01,8.2,1.28,3,0,1
[gmic_gimp_qt]./error/ When running command 'v -99 gcd_normalize_brightness 0.01,8.2,1.28,3,0,1', this error occured:
*** Error in ./gcd_normalize_brightness/*if/ac/(...)/mix_rgb/*repeat/mix_channels/*if/ *** Command 'input': Invalid argument '((66,129,25;-38,-74,112;112,-94,-18))'.
[gmic_gimp_qt]./preview/ v -99 mc_fx_zonesystem9_preview 1,10,0,255,0,0,0,0,0,0,2.5,1.7,1,0
[gmic_gimp_qt]./apply/ v -99 mc_fx_zonesystem9 1,10,0,255,0,0,0,0,0,0,2.5,1.7,1,0
[gmic_gimp_qt]./error/ When running command 'v -99 mc_fx_zonesystem9 1,10,0,255,0,0,0,0,0,0,2.5,1.7,1,0', this error occured:
*** Error in ./mc_fx_zonesystem9/apply_parallel/_apply_parallel/(...)/mix_rgb/*repeat/mix_channels/*if/ *** Command 'input': Invalid argument '((0.0016174760784313726,0.001402259215(...)1960784313727,0.0037266827450980391))'.
è
[gmic_gimp_qt]./preview/ v -99 iain_constrained_sharpen 0.75,2,1,5,0,11,1
[gmic_gimp_qt]./error/ When running command 'v -99 iain_constrained_sharpen 0.75,2,1,5,0,11,1', this error occured:
*** Error in ./iain_constrained_sharpen/*repeat/*local/(...)/mix_rgb/*repeat/mix_channels/*if/ *** Command 'input': Invalid argument '((66,129,25;-38,-74,112;112,-94,-18))'.
[gmic_gimp_qt]./apply/ v -99 iain_constrained_sharpen 0.75,2,1,5,0,11,1
[gmic_gimp_qt]./preview/ v -99 gcd_hsl_preview 1,0,0,46.45,0.04,0,1,0.77,0
[gmic_gimp_qt]./apply/ v -99 gcd_hsl 1,0,0,46.45,0.04,0,1,0.77,0
[gmic_gimp_qt]./error/ When running command 'v -99 gcd_hsl 1,0,0,46.45,0.04,0,1,0.77,0', this error occured:
*** Error in ./gcd_hsl/*repeat/*local/rgb2ycbcr/mix_rgb/*repeat/mix_channels/*if/ *** Command 'input': Invalid argument '((66,129,25;-38,-74,112;112,-94,-18))'.
Seems a color space conversion problem, Something is changed?
my mc_fx_zonesystem9 custom command:
#@gui Mc Zone system9 : mc_fx_zonesystem9, mc_fx_zonesystem9_preview(1)
#@gui : Shadows zone = float(1,1,5)
#@gui : Highlights zone = float(10,6,10)
#@gui : Black point = int(0,0,255)
#@gui : White point = int(255,0,255)
#@gui : Contrast = float(0,-50,50)
#@gui : Gamma = float(0,-50,50)
#@gui : Saturation = int(0,-70,70)
#@gui : color adj = bool(0)
#@gui : cool /warm = int(0,-50,50)
#@gui : sharp den = bool(0)
#@gui : sharp amount = float(2.5,0,10)
#@gui : sharp thres = float(1.7,0,255)
#@gui : denoise = int(1,0,10)
#@gui : sep = separator(), Preview type = choice("Full","Forward horizontal","Forward vertical","Backward horizontal","Backward vertical","Duplicate top","Duplicate left","Duplicate bottom","Duplicate right")
#@gui : sep = separator(), note = note("<small>Author : <i>Tom Keil mod by Telperion</i>.      Latest update: <i>2017/22/10</i>.</small>")
mc_fx_zonesystem9 :
-if {$10==1}
   -apply_parallel "
   fx_unsharp_octave_par 4,5,$11,$12,0,1,0,0
-endif
-apply_parallel "
-to_rgb
-rgb2lab -s c -n[0] {{$1-1}*10}%,{$2*10}% -a c
-lab2rgb
-fx_apply_curve 0,$3,0,$4,255,-1,128,-1,128,-1,128,255,1,7,0,0,0
-fx_channel_processing 0,$5,$6,0,0,0,100,256,0,0,0,2,0,0
-fx_adjust_colors 0,0,0,0,$7,0,50,50
-if {$8==1}
   -jl_colorgrading 0,$9,1,1,0,0,0,0,0,0,1,0,0,0,70,0,0,0,0,0,70,180,0,1,0,0,0
-endif
-if {$9==1}
   -apply_parallel "
   denoise $13,$13,3
-endif
mc_fx_zonesystem9_preview :
-gui_split_preview "-mc_fx_zonesystem9 ${1--2}",$-1
same problem here:
https://github.com/dtschump/gmic/issues/103
PostPosted: Fri Jan 18, 2019 10:37 am  (#5)
This is solved by David.
After refresh the filters will work.
 Post subject: Re: 17 jan 2019 h 18.00 what happen? [SOLVED]
PostPosted: Fri Jan 18, 2019 11:18 am  (#6)
tnx to David
