It is currently Wed Nov 25, 2026 5:30 am
 Post subject: Problems with the G'MIC plug-ins for gimp2.10 windows
PostPosted: Sun Jan 20, 2019 9:58 am  (#1)
Hi! I have downloaded the G'MIC plug-ins for GIMP 2.10 for windows and I can not see it in the menu of Filters, I watched the video about the modifications we need to do in the "preferences" and I did everything but still I can't see it, what I am doing wrong? I must say I am beginner user in GIMP!! thank you everybody!
 Post subject: Re: Problems with the G'MIC plug-ins for gimp2.10 windows
PostPosted: Sun Jan 20, 2019 11:05 am  (#2)
I have mine like this: After I downloaded the ZIP folder and extracted the files, I place the "Whole Folder" into my user gimp directory: C:\Users\Pocholo\AppData\Roaming\GIMP\2.10\plug-ins\gmic_gimp_qt.
Go to: Edit> Preferences, click on the "Folders" dropdown and then Plug-ins. Click on the little icon Page and the click on the Folder icon on the right and another window will popup.
From the left side choose your User Gimp directory: YourName\AppData\Roaming\GIMP\2.10\plug-ins\gmic_gimp_qt.
After that close Gimp and Re-start Gimp and you will have it on the Filters menu.
PostPosted: Sun Jan 20, 2019 11:53 am  (#3)
First, please. Gimp 2.10 no longer requires adding a folder to the plug-in paths providing the folder is the same name as the plugin. so for gmic_gimp_qt.exe the folder name is gmic_gimp_qt
Next, why is no plugin showing? Using a 32 bit Windows? The 32 bit gmic installer is broken.
Installed gmic looks like this.
Should look like this.
Solution use the zip file https://gmic.eu/files/windows/gmic_gimp ... _win32.zip for 32 bit installations.
64 bit Windows, use the installer, that is all you have to do.
PostPosted: Sun Jan 20, 2019 3:02 pm  (#4)
Thank you Pocholo for your detailed answered!
As you said rich2005 it was a problem of the 32 bit installation, I just copied the files of which you provided the link and now it is working! Thank you soo much!!
PostPosted: Tue Jan 22, 2019 11:03 am  (#5)
Hello, I've recently downloaded the latest version of Gimp and I want to add G'mic to it. Problem is when I go to the G'mic website and click on 'download' nothing happens? does anyone know if there is a problem with the download link? I've tried it with Edge, Chrome and IE but it's still not working? Help :)
