It is currently Wed Nov 25, 2026 3:44 am
 Post subject: G'Mic in Gimp portable samj
PostPosted: Sun Feb 03, 2019 2:57 am  (#1)
The latest version of G'mic is 2.4.5.
https://gmic.eu/reference.shtml
In my portable version of samj the version is 2.4.2
How to go from 2.4.2 to 2.4.5?
 Post subject: Re: G'Mic in Gimp portable samj
PostPosted: Sun Feb 03, 2019 3:56 am  (#2)
...How to go from 2.4.2 to 2.4.5?
The same as any other Gimp the samj portable has a Gimp profile. Wherever you installed it, leading to....\Gimp-2.10.6_Portable-32bit-64bits\Preferences\
That contains a plug-ins folder for your plugins, which already has the gimc_gimp_qt folder. Move this out of the plug-ins folder to somewhere safe as a backup in case of mishaps. Then
Download the up-to-date gmic zip. https://gmic.eu/files/windows/gmic_gimp ... _win64.zip
Unpack the zip, put it in the ...\Gimp-2.10.6_Portable-32bit-64bits\Preferences\plug-ins folder.
Does it work, it does here.
PostPosted: Sun Feb 03, 2019 12:06 pm  (#3)
Image rich2005
1000 thanks ImageImage it's done :)
Thank you also for the advice to save the old G'Mic, in case ...
PostPosted: Thu Feb 21, 2019 4:57 am  (#4)
:wvy rich0005,using this morning Samj Gimp portable, 32bits, to test Fractalius.8bf, I saw that the version of G'Mic is not the last.Pensant that it needed the 2.4.5 in 32 bits (?) I went on the download of G'Mic but he offers me the 64-bit version.
Edit: Do I have to take the first one from this list?
PostPosted: Thu Feb 21, 2019 7:36 am  (#5)
You have me using Windows more than since 2003 :) More testing with samj portable 2.10.8 32 V2 32bit
The 32 bit version of gmic_gimp_qt has not been updated since version 2.4.2, the same as the samj 32 bit version, so not possible to update it.
Pulled out an old version of fractalius from my archive, that works https://i.imgur.com/nj8O1hq.jpg
Note: PSPI only works with .8bf plugins and even then, not all of them.
PostPosted: Thu Feb 21, 2019 8:13 am  (#6)
rich005,Sorry to have bored you so! ;)
The plugin Fractalius works very well and I made 2 projects this morning with him! :)
I was just wondering if it was necessary to update the 32 bit G'MIC but it is not important since I can go from 32 bits to 64 and vice versa!
