It is currently Wed Nov 25, 2026 2:25 am
 Post subject: How do I install G'MIC on Gimp 2.10.8 portable?
PostPosted: Tue Mar 12, 2019 4:57 am  (#1)
I recently changed from an older Partha build 2.10 portable to Portable Apps 2.10.8. I downloaded G'MIC for Gimp, zip format, and unzipped it, placing the entire folder into Gimp's plugins folder. When booting up Gimp, I can see it is querying the G'MIC plugin but when Gimp is open, I cannot find it either in the menu or in the plugin browser.
 Post subject: Re: How do I install G'MIC on Gimp 2.10.8 portable?
PostPosted: Tue Mar 12, 2019 6:06 am  (#2)
Guessing this one: https://portableapps.com/apps/graphics_ ... p_portable
Most likely the problem is portableapps Gimp 2.10.8 is a 32 bit application for maximum portability. You need the 32 bit version of gmic_gimp_qt https://gmic.eu/files/windows/gmic_gimp ... _win32.zip This has not been updated since last December, you get version 2.4.2. Good for most things.
Unzip, put the whole gmic_gimp_qt folder in the location indicated by Edit -> Preferences -> Folders -> plug-ins
However, assuming my test install is valid, serious issues with this Gimp version.
The Gimp profile is not fully populated. No ...GIMPPortable\Data\.gimp\plug-ins folder. Just make one, it works.
More serious. Python is broken. Check bottom of the Filters menu. There is a Script-Fu entry but no Python-Fu. Quick test with a simple python plugin - nothing.
PostPosted: Tue Mar 12, 2019 6:15 am  (#3)
Thanks Rich. I'll try it to see if there are any issues in case anybody else has the same problem but I would like to use 64 bit so I have downloaded Samj's 2.10.9 with G'MIC already installed. I'll just have to find out how to change the default Gimp settings to those I am used to working with. Thank you again.
cron
