It is currently Tue Nov 24, 2026 10:39 pm
 Post subject: G'Mic Wild Cartonizer Photocomix
PostPosted: Sat Jul 13, 2019 12:14 pm  (#1)
:wvy
No problem for this filter with samj Gimp 2.10.11 and samj Gimp2.10.8 but with samj Gimp 2.10.12 I get this error message:
 Post subject: Re: G'Mic Wild Cartonizer Photocomix
PostPosted: Sat Jul 13, 2019 2:13 pm  (#2)
This is the problem with portable versions, Windows or Linux, you get what you are given.
However in this case, not much you can do. The gmic_gimp_qt in the samj's Gimp 2.10.12 is version 2.6.6 and at least 3 weeks old ;) As of yesterday gmic_gimp is up to 2.70 and the photocomix wild cartoonizer still gives that error. Older versions - gmic_gimp_qt 2.5.7 are ok but since then the gmic syntax has changed.
What you should do is report the bug to David Tschumperlé and the best place is https://discuss.pixls.us/t/release-of-g ... /12240/210
However as a sort of a fix:
Download and unzip the attached update266.gmic file.
Rename the existing file in the samj ...\GMIC_Filters\gmic folder as a backup
Copy the new update266.gmic file to there. example.
Should be working but whatever you do do not update the filters or you might get the original back.
update266.gmic.zip [930.76 KiB]
Downloaded 342 times
PostPosted: Sun Jul 14, 2019 12:37 am  (#3)
Thanks rich2005 for reporting this error. :)
1) Thank you for this method but is not it embarrassing to not be able to update for other filters?
2) I already have an update 2.6.6 file:
Why put the same?
3) If I put the installable version on C, will I be able to continue using old portable versions that are on D?
PostPosted: Sun Jul 14, 2019 4:09 am  (#4)
It is worth remembering that gmic constantly evolves. samj 2.10.11 used an older gmic_gimp 2.5.7 while samj 2.10.12 uses 2.6.6
Between those versions there was a change in the way gmic interprets the commands, which is why wild cartooniser gives that error. It was never updated.
All those 'testing' filters are in a big script file updatexxx.gmic which matches the gmic version. Normally when you install gmic_gimp it has 312 filters and updates to 520. It downloads all of the testing section.
I am no expert in gmic syntax but I guessed a small change to line 61915 was required.
from -unsharp $3,$4,0[1] to -unsharp[1] $3,$4,0
Which is why you need to replace it with the zipped version
The samj gmic_gimp_qt is a bit strange. I do not know if it is possible to upgrade gmic_gimp to a newer version. Maybe one of the regular users can give advice.
Yes, I have that setup on my Win10 (VM)
PostPosted: Sun Jul 14, 2019 6:04 am  (#5)
thank you rich2005 Image
