It is currently Tue Nov 24, 2026 3:55 pm
 Post subject: I can’t find Gmic in Gimp
PostPosted: Fri Jan 17, 2020 5:03 pm  (#1)
I have downloaded Gimp 2.10.14 and G'Mic 2.8.2, but I cannot find G'mic in Gimp.
Could it be that because I have too many scripts and plug-ins it is somewhere else?
If not, what can I do best? :tyspin
 Post subject: Re: Ik kan G'mic niet vind in Gimp
PostPosted: Fri Jan 17, 2020 5:23 pm  (#2)
1. You have to use folder options in Windows Explorer and set "Show hidden folders" to yes, because Gimp user folder is in C:/Users/yourname/AppData/Roaming/Gimp/2.10
2. Extract the G'mic archive, and put it in the C:/Users/yourname/AppData/Roaming/Gimp/2.10/plug-ins
3. Speak English, thank you.
G'mic can be found in Filters/G'mic-Qt
 Post subject: Re: I can’t find gmic in Gimp
PostPosted: Fri Jan 17, 2020 5:46 pm  (#3)
Thank you, solved. :tyspin
PostPosted: Fri Jan 17, 2020 6:08 pm  (#4)
You're welcome, have a nice weekend and keep gimping!
