It is currently Tue Nov 24, 2026 11:46 am
 Post subject: GMIC (GIMP) Kaleidoscope now has two [Polar] entries, but no [Blended]
PostPosted: Fri Feb 28, 2020 2:28 pm  (#1)
GMIC (GIMP) Kaleidoscope now has two [Polar] entries, but no [Blended] entry. What happened?
 Post subject: Re: GIMP Kaleidoscope now has two [Polar] entries, but no [Blended]
PostPosted: Fri Feb 28, 2020 3:02 pm  (#2)
here?
 Post subject: Re: GMIC (GIMP) Kaleidoscope now has two [Polar] entries, but no [Blen
PostPosted: Sat Feb 29, 2020 3:35 pm  (#3)
manjaro 19.0.1, gimp 2.10.18, gmic-qt 2.8.4_pre*. after manjaro/gimp/gmic updates, the gmic kaleidoscope [blended] filter dissappeard. tried uninstalling gmic/gimp and reinstalling, but this did not fix the issue.
PostPosted: Sat Feb 29, 2020 3:40 pm  (#4)
Maybe it was deleted in G'mic 2.8.4, it's still listed in 2.8.3.
PostPosted: Sat Feb 29, 2020 4:09 pm  (#5)
This is as up-to-date as I have at the moment. kubuntu 18.04 / Gimp appimage / gimp-gmic 2.9.0 (compiled about a week ago).
Maybe try an update, although apart from a few filters that appeared in the testing section I do not see much change between versions. The code changes seem to be aimed at the stand-alone gmic.
PostPosted: Sat Feb 29, 2020 5:26 pm  (#6)
Won't be updating GMIC anymore then. I use blended the most.
PostPosted: Wed Mar 04, 2020 7:22 pm  (#7)
The GMIC distributions for OS distros (manjaro, mint, kubuntu, etcetera) do not appear to be in synch. Evidently Kaleidoscope [BLEND] is in some 2.8.4+ versions , but not others.
As well, a fairly bad Kaleidoscope [BLEND] bug has been uncovered in GMIC 2.8.0 (Manjaro) release wrt intermediate data. It would require more time to debug the issue, but the command is picking up data from one GIMP project file, and using it in both the preview and final output for the project file being edited. It's only a guess, but the Ka [BLEND] author likely already knows about the issue.
PostPosted: Thu Mar 05, 2020 11:58 am  (#8)
This is where I get my G'mic updates for Linux 64-bit: https://github.com/aferrero2707/gimp-pl ... continuous
Currently using G'mic 2.8.5 and it does have Blend. Download the G'mic AppImage, make it executable and run it. Then locate the "gmic_gimp_qt" and put it into your user Gimp plugins folder.
cron
