It is currently Tue Nov 24, 2026 9:53 am
 Post subject: G'mic 2.9.0
PostPosted: Sat Mar 28, 2020 4:00 pm  (#1)
New filter. Rendering > Tree.
 Post subject: Re: G'mic 2.9.0
PostPosted: Sat Mar 28, 2020 5:12 pm  (#2)
Thanks for discovering David had put an artificial tree growing filter into G'MIC :clap
I used the color-picker tool to put a hex color from a nearby tree into the filter. Some more texture/shading on the trunk would be good but it's a fun filter.
PostPosted: Sat Mar 28, 2020 5:17 pm  (#3)
Tas_mania, In which category is this Tree Filter? I guess I need to update my G'MIC again. Your image is very nice. I like it a lot.
Thank you, Racer, good find. Thanks for sharing. Your image is nice also.
PostPosted: Sat Mar 28, 2020 5:18 pm  (#4)
It's under 'Rendering'
You can also use the search box in G'MIC :)
