It is currently Tue Nov 24, 2026 6:45 am
 Post subject: Unknown command or filename error - Used to work fine until now...
PostPosted: Thu Nov 26, 2020 1:41 pm  (#1)
Hi All!
I'm using Gimp since June and everything was working fine. I was experimenting with all the G'MIC filters and everything was working fine. But this week some filters started to give errors. The filter I was most interested in was "Dreamy Watercolour" but unfortunately, it doesn't work anymore. I'm not sure what I did for this to happen. I did a search to see if someone had this issue but found nothing. Has this happened to anyone else? With these specific missing commands\files?
I use Windows 8.1, GIMP 2.10.22, G'MIC 2.9.4
The error I get in the preview is:
PREVIEW ERROR
*** Error in ./fx_dreamy_watercolour/*repeat/*local/(...)
/_apply_channels/*repeat/*local/_ac/ ***
Unknown command or filename '_jr_fx_noise'; did you
mean '_fx_noise'?
I attach a JPG screenshot.
If someone could give me some clues to solve this issue I would be very grateful. :yes
 Post subject: Re: Unknown command or filename error - Used to work fine until now...
PostPosted: Thu Nov 26, 2020 2:27 pm  (#2)
Just checked: I confirm, same error on Windows 10, Gimp 2.10.23, G'mic 2.9.3
PostPosted: Thu Nov 26, 2020 3:05 pm  (#3)
I can also confirm this bug in the G'mic-2.9.3/4 version.
You have to wait for David to fix it and it will be faster when you report a bug on https://discuss.pixls.us/.
Immediate solution:
It works in version 2.8.4 (because it doesn't update anymore - so the file is attached).
Download: https://gmic.eu/files/windows/
update284.zip [1022.63 KiB]
Downloaded 174 times
PostPosted: Thu Nov 26, 2020 6:22 pm  (#4)
Immediate solution:
Thank you MareroQ, this solution will do for now. Many thanks :tyspin
PostPosted: Fri Nov 27, 2020 4:00 am  (#5)
No need for my dubious fix ;) As posted next by Grat99
PostPosted: Fri Nov 27, 2020 4:03 am  (#6)
Just to let everyone know that this issue has been resolved thanks to David.
It is fixed, after pressing the "refresh filters" button, with Internet checkbox enabled.
I can't post a link but in the reddit forum of GMIC he replied and fixed the issue.
Thank you David!
