It is currently Tue Nov 24, 2026 6:20 am
 Post subject: Filter Cubisme A (samj)
PostPosted: Wed Jan 13, 2021 6:08 am  (#1)
:wvy
I applied the filter with the data from samj here: https://samjcreations.blogspot.com/2021 ... sme-a.html
samj_Test_Cubisme_A 1,120,70,1,50,100,5,0,6,0,1,300,15,10,40,80,1,1,5,1,1,64,25,8,1,0
with the image of the glass (Tamanna Rumee: https: //unsplash.com/photos/310GkTAyHIo
and the rendering is not identical.
I started again several times by checking the 26 boxes and also with Gmic / various / custum code
 Post subject: Re: Filter Cubisme A (samj)
PostPosted: Wed Jan 13, 2021 9:31 am  (#2)
Did a run and got this:
Cubisme A samj_Test_Cubisme_A 1,120,70,1,30,30,2,0,6,0,1,300,8,10,10,20,1,1,5,1,1,64,25,8,1,0.jpg
Cubisme A samj_Test_Cubisme_A 1,120,70,1,30,30,2,0,6,0,1,300,8,10,10,20,1,1,5,1,1,64,25,8,1,0.jpg [ 1.16 MiB | Viewed 4644 times ]
Is this what you got?
If yes, I totally confirm your comment.
PostPosted: Wed Jan 13, 2021 10:13 am  (#3)
dinasset,my rendering are less beautiful than yours ... :)
the first by entering the numbers indicated 1 by 1:
and the 2nd by pasting in various local:
mais je vois que vous n'avez pas mis les mêmes paramètres indiqués par samj:
PostPosted: Wed Jan 13, 2021 10:50 am  (#4)
I just started over with the same parameters indicated by samj put in fave and after a new update of the filters (which I do all the time), it's still different ..
I'm giving up for today
PostPosted: Sat Jan 16, 2021 3:37 am  (#5)
I understand you, level_0.
To be honest, I "hate" filters with many parameters, hence I rarely try them.
If you ever tried to use some of my filters, you will have seen a limited number of parameters, IMHO the author has to do his/her choices and leave just 1 to 7 options to the user.
But that is my personal point of view.
PostPosted: Sat Jan 16, 2021 2:40 pm  (#6)
dinasset,I gave up my tests of this filter. :)
