It is currently Tue Nov 24, 2026 6:02 am
 Post subject: [Solved] How to identify the new filters?
PostPosted: Sun Jan 17, 2021 12:01 am  (#1)
:wvy
2 days ago I had 548 filters and today 550.
How do I identify the 2 new ones? :gaah
 Post subject: Re: How to identify the new filters?
PostPosted: Sun Jan 17, 2021 12:39 am  (#2)
I don't know either.
Hope someone more "inside" G'mic can answer.
PostPosted: Sun Jan 17, 2021 1:23 am  (#3)
best place to goto find out would be
GMIC Community
PostPosted: Sun Jan 17, 2021 2:43 am  (#4)
sallyanne, I think that here on GC some should know ....
PostPosted: Sun Jan 17, 2021 3:01 am  (#5)
@level_0
I posted your question on the GMIC Community as suggested by Sallyanne.
Let's see if I get the answer.
PostPosted: Sun Jan 17, 2021 3:19 am  (#6)
Maybe, but in that link I gave it is the same link as on the GMIC page and the people on that page who go there are the contributors to GMIC (some of them anyway)
PostPosted: Sun Jan 17, 2021 5:07 am  (#7)
@level_0
First answer received:
"No, but the authors usually add the updated date in the description."
PostPosted: Sun Jan 17, 2021 5:25 am  (#8)
For some time I have thought too many filters, mostly appear in the testing section and most frequently from reptorian, afre, sometimes joan rake.
from 547 to 550 filters comparing updatexxx.gmic files.
The latest three are all reptorian: dynamic contrast / reverse engineer gradient map / reverse engineer color map
For info, the list of filters is here: https://gmic.eu/gui_filters.txt but it is the current list and unless you keep a record of old versions nothing to compare.
PostPosted: Sun Jan 17, 2021 12:59 pm  (#9)
I received additional replies from G'mic experts, but the answer is still "no" (there is currently no way to ask about what is new after an internet update).
PostPosted: Sun Jan 17, 2021 2:43 pm  (#10)
@level_0
good news, David T. (the "boss" of G'mic) is saying that it could be created a new filter to show what's new after an update.
PostPosted: Mon Jan 18, 2021 9:05 am  (#11)
Thank you all for your responses. :)
@level_0
@level_0
Thank you dinasset
PostPosted: Mon Jan 18, 2021 10:13 am  (#12)
Pas de quoi, Madame
PostPosted: Mon Jan 18, 2021 10:27 am  (#13)
...and David just did it!
Received :
New filter About / What’s New? has been added.
It will list the added and deleted filters from your last visit (to the filter).
PostPosted: Mon Jan 18, 2021 11:03 am  (#14)
That was done quickly
You beat me to it dinasset
Here's a pic
PostPosted: Fri Jan 22, 2021 3:59 am  (#15)
:wvy
I only see today that the problem is solved!Image
Thanks to dinasset and thanks to David Tschumperlé for his responsiveness! :clap
