It is currently Tue Nov 24, 2026 5:26 am
 Post subject: GMIC Wild cartoonizer Photocomix
PostPosted: Mon Feb 15, 2021 10:40 am  (#1)
:wvy
Photocomix's Wild Cartoonizer filter gives 2 layers.Image
Why?
 Post subject: Re: GMIC Wild cartoonizer Photocomix
PostPosted: Mon Feb 15, 2021 1:53 pm  (#2)
Since it was his only GMIC filter that created a duplicate layer, we may never know why PC added this option. I know that he utilized duplicate layers for his arrays/mirrors experiments, since he liked to clash different psychedelic layer orientations against one another into patchworks. AFAIK none of those experiments were hard coded to leave duplicate layers. Some of his artwork/resources can be seen at https://www.deviantart.com/photocomix-resources/t and his Flickr is at https://www.flickr.com/photos/photocomix-mandala/
PostPosted: Mon Feb 15, 2021 11:51 pm  (#3)
Photocomix G'MIC code is here.
I can get rid of doubling layers by adding this before the second last line of the Wild Cartoonizer filter.
-blend overlay
PS. I'm just a newbie at G'MIC code but I learned how to make my own filter code entry in G'MIC where I can play around with the filters.
I tested on 90 layers and then added Photocomix Psychedelic Glasswork Tiler.
PostPosted: Wed Feb 17, 2021 7:34 am  (#4)
-blend overlay
Great outcome Tas! well done
PostPosted: Thu Feb 18, 2021 7:10 pm  (#5)
Thanx for the like akky.
I experimented with SamJ's Skeletik filter on a landscape background. This is the GIF result.
PostPosted: Fri Feb 19, 2021 5:05 pm  (#6)
so finally no solution for the levels 0 like me ... but no one died :(
PostPosted: Fri Feb 19, 2021 6:35 pm  (#7)
Making your own filter is easy. I found instructions here.
My filter only has 1 line:
#@gui My first filter: my_first_filter_command, my_first_filter_command_preview
and below I pasted the whole Wild Cartoonizer code from here.
Photocomix made that easy because his filters are so well separated. Then do the mod I found and you have just one layer output.
PostPosted: Sat Feb 20, 2021 7:48 am  (#8)
Thanks very much Tas_mania. I'll try. :)
