It is currently Tue Nov 24, 2026 3:56 am
 Post subject: today error on some G'MIC filters (fixed on pre 2.9.8)
PostPosted: Sat May 08, 2021 11:26 pm  (#1)
Just browsing some G'mic filters on "Contours"and found these errors (I did update the filters definitions via Internet).
Environment: Gimp 2.10.24 rev.3 + G'mic 2.9.7
 Post subject: Re: today error on some G'MIC filters
PostPosted: Sun May 09, 2021 5:00 am  (#2)
Your version of G'mic has issues, try another. All three filters work here in G'mic 2.9.8
PostPosted: Sun May 09, 2021 5:42 am  (#3)
The gmic_gimp_qt syntax is frequently changing and breaking filters.
Some times better to go back a stable version and check if the required filters work. Latest (today) I found with my compiled plugin 2.9.8 , the 'finger paint' filter not working. Compiled it again with latest code and that is working again. But with 405 filters + another 163 in 'testing' you might never find the broken ones until you need them. David will fix in the main section when informed but 'testing' is another matter.
PostPosted: Sun May 09, 2021 5:52 am  (#4)
The attachment gmic.png is no longer available
Thanks.
Usually (not always) I prefer to keep on a "stable" version, and currently 2.9.7 is the "stable" one
Maybe I will move up to the pre-release.
PostPosted: Sun May 09, 2021 5:55 am  (#5)
Thanks Rich, I just posted those info for David, he may check whether there is a need for fixes or whether all have been aleady done in 2.9.8.
PostPosted: Sun May 09, 2021 6:13 am  (#6)
post-scriptum:
following the info provided by racer-x, I downloaded the pre-release 2.9.8; those filters work, hence the problems have been fixed already there. Thanks.
 Post subject: Re: today error on some G'MIC filters (fixed on pre 2.9.8)
PostPosted: Mon May 10, 2021 4:54 am  (#7)
dinasset, :wvy you downloaded this one which contains these folders?
PostPosted: Mon May 10, 2021 7:50 am  (#8)
NO, the gmic_gimp2.10_win64.zip I downloaded includes only gmic_gimp_qt.
If you use Samj's package, go to Preferences/plug-ins, rename the existing gmic_gimp_qt in something like gmic_gimp_qt-OLD, then place there the gmic_gimp_qt you just downloaded from gmic.eu.
PostPosted: Tue May 11, 2021 2:03 am  (#9)
thank you dinasset, I will rename with the number as you explained to me before. :)
