It is currently Tue Nov 24, 2026 4:07 am
 Post subject: SAMJ package update for Gmic
PostPosted: Mon May 10, 2021 10:46 am  (#1)
Published on https://samjcreations.blogspot.com/2021 ... 5713783727
For all users of SAMJ's portable Gimp.
BTW, if you like mosaics, you may take the opportunity to create one using Samj's Mosaic A.
I did.
2021-05-10 17-40-00 65b44661ce56090e1e1dec1075b0e4f1 as a Mosaic xreated using Sylvie Mosaic A.jpg
2021-05-10 17-40-00 65b44661ce56090e1e1dec1075b0e4f1 as a Mosaic xreated using Sylvie Mosaic A.jpg [ 745.59 KiB | Viewed 6333 times ]
 Post subject: Re: SAMJ package update for Gmic
PostPosted: Mon May 10, 2021 12:33 pm  (#2)
Thanks Dinasset for tell us about this filter. Really beautiful. :jumpclap
PostPosted: Mon May 10, 2021 12:44 pm  (#3)
You're welcome.
If you like to get the "light" effect from the top instead of the bottom (the filter does not have an option yet), simply flip vertically the source before calling the filter, then again after the run (so I did).
PostPosted: Mon May 10, 2021 12:52 pm  (#4)
What a bright idea!
Just I did it.
PostPosted: Mon May 10, 2021 12:58 pm  (#5)
Then you may play creating a BG (the mosaic, when called with the option "create new layer", has the tile separators transparent). I did.
PostPosted: Mon May 10, 2021 12:59 pm  (#6)
...and you may increase a bit the tile size (option on the filter).
