It is currently Tue Nov 24, 2026 3:08 am
 Post subject: Curves - preview error [solved]
PostPosted: Wed Jun 09, 2021 12:15 am  (#1)
Hi David.
Can you check it out?
 Post subject: Re: Curves - preview error.
PostPosted: Wed Jun 09, 2021 3:22 am  (#2)
I am sure David will answer soon
What I see is
Using a (linux) compiled 2.9.8 from 29 May, which is OK. There is a change in the code yesterday https://github.com/dtschump/gmic which might be a fix. Compiled that and no color-curves preview error. Your version is 4 June, the latest Windows (from http://www.gmic.eu ) 2.9.8 is 8 June, might be worth an update or wait a bit for the next one.
 Post subject: Re: Curves - preview error [solved]
PostPosted: Fri Jun 11, 2021 10:40 am  (#3)
Thanks Rich2005. :hi5
As always, You were right. ;)
