It is currently Tue Nov 24, 2026 2:52 am
 Post subject: G'MIC Watercolor Effect?
PostPosted: Sun Aug 01, 2021 5:35 pm  (#1)
Where is the "Watercolor effect" filter in G'MIC? Came across a tutorial that uses it and would like to experiment. But I can't find the filter itself in the current list of G'MIC 564 filters. Has it been eliminated? If so, any replacements or alternatives? THX!
 Post subject: Re: G'MIC Watercolor Effect?
PostPosted: Sun Aug 01, 2021 9:39 pm  (#2)
I found two in G'MIC:
Testing> Joan Rake> Artistic> Dreamy Watercolor
Testing> Samj> Isophotes Vers Aquarelle
The actual name of the effect you're looking for may be helpful.
PostPosted: Sun Aug 01, 2021 10:11 pm  (#3)
May be you'll like this one, Artistic > Dream smoothing
People who made filters in G'MIC might want to rename them for multiple reasons and they are free to do it.
The first reason which come in my mind is because they added more functionalities to their filter, de-facto the original filter do a lot more than the original naming, thus they rename it ;)
other than trying the 1122 filters to find it back under a new name... (yes 1122 filters > https://gmic.eu/gui_filters , the Testing group (+>550) is not taken in count when you see 569 filters)
EDIT,
to not "lose" a filter in the future, it's a good idea to keep your favorite filters in your "Faves", right click on a filter > add to faves, once in your faves, you can even rename them, right click on the filter in your Faves > rename
Patrice
PostPosted: Tue Aug 03, 2021 5:47 am  (#4)
I am not sure when it was phased out but it is not there now ;) I can get it in a (linux) Gimp 2.8 and a gmic_gimp (gtk) 1.7.5
Lots of sliders, Looks like this:
PostPosted: Tue Aug 03, 2021 6:54 am  (#5)
You can also try Gimp's "Waterpixels" filter.
PostPosted: Tue Aug 03, 2021 11:46 pm  (#6)
I just learned that the author commented his script (so it's here, but in comment = don't show up)
what you can do is to create a ".gmic" file or "user.gmic" depending your OS in your home directory and put this code:
#@gmic
#@gui _<b>Artistic</b>
# watercolor
#@gui Watercolor : fx_watercolor, fx_watercolor_preview(1)
#@gui : sep = separator(), note = note("General settings:")
#@gui : Color Intensity = float(1.8,0,4)
#@gui : Light Colors = float(0.1,0,1)
#@gui : Dark Colors = float(1,0,10)
#@gui : sep = separator(), note = note("Line art settings:")
#@gui : Line Art Details = float (80,50,100)
#@gui : Line Art Smoothness = float(0,0,10)
#@gui : Line Art Strength = float(0.5,0,1)
#@gui : Line Art Style = choice("pencil","ink","comic style")
#@gui : Line Art Fade = float(0,0,100)
#@gui : sep = separator(), note = note("Color brushes settings:")
#@gui : Brush Style = choice("modern","classic","abstract","line","smooth")
#@gui : Cyan Brush Size = float(2,0,50)
#@gui : Cyan Stroke Strength = float(0,-5,5)
#@gui : Cyan Edge Distance = float(2,0,10)
#@gui : Cyan Abstraction = float(4,0,10)
#@gui : Magenta Brush Size = float(2,0,50)
#@gui : Magenta Stroke Strength = float(0,-5,5)
#@gui : Magenta Edge Distance = float(3,0,10)
#@gui : Magenta Abstraction = float(3,0,10)
#@gui : Yellow Brush Size = float(2,0,50)
#@gui : Yellow Stroke Strength = float(0,-5,5)
#@gui : Yellow Edge Distance = float(4,0,10)
#@gui : Yellow Abstraction = float(2,0,10)
#@gui : sep = separator(), note = note("Paper and ambience settings:")
#@gui : Paper Color Black = bool(0)
#@gui : Add Paper Texture = bool(0)
#@gui : Invert Colors = bool(0)
#@gui : Ambient Light = float(0,-50,50)
#@gui : sep = separator(), Preview type = choice("Full","Forward horizontal","Forward vertical","Backward horizontal","Backward vertical","Duplicate top","Duplicate left","Duplicate bottom","Duplicate right","Duplicate horizontal","Duplicate vertical","Checkered","Checkered inverse")
#@gui : sep = separator(), note = note("<small>Authors : <i>Tom Keil and Arto Huotari </i>       Latest update: <i>2011/19/02</i>.</small>")
#@gui : note = link("Tutorial download","http://www.slideshare.net/ArtoHuotari/gmig-water-color-filter-tutorial")
#@gui : note = link("Video demonstration here","http://vimeo.com/19713850")
fx_watercolor :
  repeat $! l[$>] split_opacity l[0]
  #secure details:
  if $7==0 +fx_gradient_norm $5,0.5,{99.99-$4},$4,1,0
  elif $7==1 +fx_edges {$5/3.5},{95-$4},0,0
  elif $7==2 +fx_edges {$5/3.5},{95-$4},0,0
  +fx_mix_hsv[0] 1,0,0,1,-1,0,1,0,0,0,2,0
  tk_fx_channel_processing[2] 1,1,0,{$5/10},4,{{$4-50}*2},100,256,0,0,0,2,7,0
  reverse[1,2] fx_compose_multiply[1,2] {0.5+{$6/2}}
  fi fx_frame_round[1] 5,$8,15,0,255,255,255,255,0,0.1,3
  #image preparation:
  fx_smooth_anisotropic[0]
  60,0.16,{{20/50}+0.6},{{20/9}+0.6},2.35,0.8,30,2,0,1,1,0,1
  [0] +negate[0] move[1] 4
  fx_gaussian_blur[2] {{w+h}/100},0,0,1,0,0,0
  fx_compose_dodge[1,2] 1
  fx_mix_lab[0] 1,0,0,$1,0,0,$1,0,0,0,2,0
  reverse[0,1]
  fx_compose_colorburn[0,1] $2
  +luminance[0] reverse[1,2]
  tk_fx_channel_processing[1] 1,1,0,0,4,{$3*5},100,256,0,0,0,2,0,0
  fx_gaussian_blur[1] $3,0,0,1,0,0,0
  tk_fx_channel_processing[1] 1,1,0,0,4,0,99,256,0,1,0,2,0,0
  tk_fx_replace_color[1] 1,0,255,255,255,255,0,0,0,0
  fx_spread[1] {$3*2},{$3*2},0,0
  fx_gaussian_blur[1] {{w+h}/1000},0,0,1,0,0,0
  reverse[0,1] fx_compose_multiply[0,1] 1
  #channel and mask creation:
  split[0] c
  if $9==0 +negate[0] +negate[1] +negate[2]
  elif $9==1 +fill_color[0] 255,255,255 +fill_color[0] 255,255,255
  elif $9==2 +fill_color[0] 255,255,255 +fill_color[0] 255,255,255
  elif $9==3 +fx_edges[0] {$10/5},{$13*5},1,0
  +fx_edges[1] {$14/5},{$17*5},1,0 +fx_edges[2] {$18/5},{$21*5},1,0
  elif $9==4 +negate[0] +negate[1] +negate[2] fi
  #channel and mask processing:
  tk_fx_channel_processing[0] 1,{{$11/5}+1},{$11/50},0,0,0,100,256,0,0,0,2,0,0
  if $9!=2
  fx_gaussian_blur[0] $10,0,0,1,0,0,0
  else cubism[0] 300,{$13*5},{$13*36},1,{$10/50} fi
  if $9==0
  tk_fx_channel_processing... 1,{{$11/5}+1},{$11/50},0,0,0,100,256,0,0,0,2,0,0
  cubism... 300,{$13*5},{$13*36},1,{$10/50} fi
  if $9==4
  fx_painting... $13,1.5,2 fi
  fx_frame_fuzzy... {$12*5},{$12*5},{$13*20},{$10/2},0,0,0,255
  tk_fx_channel_processing[1] 1,{{$15/5}+1},{$15/50},0,0,0,100,256,0,0,0,2,0,0
  if $9!=2
  fx_gaussian_blur[1] $14,0,0,1,0,0,0
  else cubism[1] 300,{$17*5},{$17*36},1,{$14/50} fi
  if $9==0
  tk_fx_channel_processing.. 1,{{$15/5}+1},{$15/50},0,0,0,100,256,0,0,0,2,0,0
  cubism.. 300,{$17*5},{$17*36},1,{$14/50} fi
  if $9==4
  fx_painting.. $17,1.5,2 fi
  fx_frame_fuzzy.. {$16*5},{$16*5},{$17*20},{$14/2},0,0,0,255
  tk_fx_channel_processing[2] 1,{{$19/5}+1},{$19/50},0,0,0,100,256,0,0,0,2,0,0
  if $9!=2
  fx_gaussian_blur[2] $18,0,0,1,0,0,0
  else cubism[2] 300,{$21*5},{$21*36},1,{$18/50} fi
  if $9==0
  tk_fx_channel_processing. 1,{{$19/5}+1},{$19/50},0,0,0,100,256,0,0,0,2,0,0
  cubism. 300,{$21*5},{$21*36},1,{$18/50} fi
  if $9==4
  fx_painting. $21,1.5,2  fi
  fx_frame_fuzzy. {$20*5},{$20*5},{$21*20},{$18/2},0,0,0,255
  to_gray. to_gray.. to_gray... to_rgba[0] to_rgba[1] to_rgba[2]
  #recombine image:
  split[0] c reverse[3,-3] compose_multiply[3,-3] append[0,1,2,3] c
  split[1] c reverse[4,-2] compose_multiply[4,-2] append[1,2,3,4] c
  split[2] c reverse[5,-1] compose_multiply[5,-1] append[2,3,4,5] c
  if $22==0 +fill_color[0] 255,255,255 else +fill_color[0] 0 fi
  reverse[0,-1]  compose_rgba[0,-1]
  if $22==0 +fill_color[1] 255,255,255 else +fill_color[1] 0 fi
  reverse[1,-1] compose_rgba[1,-1]
  if $22==0 +fill_color[2] 255,255,255 else +fill_color[2] 0 fi
  reverse[2,-1] compose_rgba[2,-1]
  to_gray[0] to_gray[1] to_gray[2] append[0,1,2] c
  if $23==1 fx_paper 0,0 fi
  if $24==1 negate[0] fi
  fx_mix_lab 1,$25,0,1,0,0,1,0,0,0,2,0
  reverse[0,1] fx_compose_multiply[0,1] $6
  endl a c endl done
fx_watercolor_preview :
  gui_split_preview "fx_watercolor ${1--2}",$-1
#*****END OF FILTER**********************
At startup, G'MIC automatically includes user's command file $HOME/.gmic (on Unix) or %APPDATA%/user.gmic (on Windows). as per https://gmic.eu/reference/adding_custom ... s.html#top
and um... I won't rewrite thing as it's all there > https://discuss.pixls.us/t/watercolor-effect/26229/3 (thanks to @afre :bigthup )
BTW if you have an alpha channel on your image remove it before launching G'MIC, or this filter will tell you that you have too much channel
Patrice
PostPosted: Wed Aug 04, 2021 3:09 am  (#7)
Hi Patrice.
I really appreciate Your actively seeking a solution for someone else.
For me, only this file location works in Windows:
c:\Users\* Your Name *\AppData\Roaming\gmic\user.gmic
The filename (before .gmic) can be anything you like (e.g.: watercolor.gmic instead of user.gmic).
This method won't work on the portable Windows version of Samj (unless someone is also using the Onkel_Hatti launchpad)
PostPosted: Wed Aug 04, 2021 5:53 am  (#8)
Thanks for the update for the Windows' users (I don't have Windows > cannot try the path)
I think for Windows (not sure) the %APPDATA% is a relative path used by programmers, they just forgot to translate it in normal English :hehe , I mean a full static path like you did :bigthup
(they did the same for Unix/Linux with the $HOME, translated it should be /home/yourname/ )
I forgot to specify about Linux (and may be macOS as they are unix) it won't work if we put a name before the extension ".gmic" as it should be a hidden file, which means that all scripts (if we need to add more scripts) will queue down in that file.
Patrice
PostPosted: Wed Aug 04, 2021 10:00 am  (#9)
Thanks for updating your info on the name.
Now it almost works for me ( preview doesn't).
I wonder why this file has to be kept in the home dir and clutter it more instead of having it in the dir where all the other GMIC stuff is.
But that's nothing you can change.
:tyspin
Regards
nelo
PostPosted: Wed Aug 04, 2021 5:14 pm  (#10)
The preview will work if you remove the alpha channel of the image prior to running G'mic. It's not a good solution though to have .gmic files in the Home folder.
PostPosted: Thu Aug 05, 2021 1:52 am  (#11)
For those interested in a Watercolor Effect (not GMIC):
viewtopic.php?f=9&t=19524
post#69
PostPosted: Thu Aug 05, 2021 3:13 am  (#12)
Thanks racer-x. That did the trick.
Regards
nelo
