It is currently Tue Nov 24, 2026 2:38 am
 Post subject: Stroke: how to remove space between test & stroke
PostPosted: Tue Oct 26, 2021 8:17 am  (#1)
Hi there and thanks for your help.
I am a 48 hour newby to GIMP and have just installed G'Mic. I am doing some tutorials. I want to apply a stroke to a text layer. But, when I apply the stroke, there is a space between the test and stroke of about 1px. How do I remove it? Or, if someone can point me to a tutorial on how to use the stroke plugin.
Thanks.
 Post subject: Re: Stroke: how to remove space between test & stroke
PostPosted: Tue Oct 26, 2021 9:02 am  (#2)
There are few different ways to create a stroke. The easier way is to have install the Layerfx plugin:
1. Go to the Layer menu and select: Layer Effect> Stroke
2. On the dialog Stroke, select the Size, Position and the Color and click Stroke.
The other way if you don't have the Layerfx plugin is:
1. Go to the Layers dialog, right click the Text layer and select, Alpha to selection.
2. Go to menu: Select and choose, "To path" to create a path (Paths are smoother)
3. Get rid of the selection, go to: Select> None
4. Set the color you want on the Foreground/Background palette
5. Go to: Edit> Stroke path and another dialog will open. Here, by default the top option is selected is "Stroke Line".
PostPosted: Tue Oct 26, 2021 10:08 am  (#3)
,,, I want to apply a stroke to a text layer. But, when I apply the stroke, there is a space between the test and stroke of about 1px. How do I remove it?
The way to avoid that is Text-to-Path then stroke the path on a layer under the text layer.
I did this for someone as an example on another forum, only one minute . https://i.imgur.com/dpWOg1X.mp4
You can also use the GEGL drop shadow flter with settings like this https://www.gimp-forum.net/attachment.php?aid=6461
PostPosted: Tue Oct 26, 2021 11:07 am  (#4)
hi.
Thank you very much to the both of you. Really appreciate your time in replying to my question.
Thanks.
