It is currently Mon Nov 23, 2026 9:03 pm
 Post subject: How to pass textvariable to GMIC from python [solved]
PostPosted: Thu Dec 30, 2021 5:20 am  (#1)
Hi all,
In a python script for GIMP 2.10 I try to implement the possibility to add a GMIC watermark.
This would be the line to use:
pdb.plug_in_gmic_qt(image,layer,1,1,"fx_watermark_visible watermarktext,0.1568,50,25,0.5,1")
How do I pass "watermarktext" as a variable to this GMIC call?
Regards
nelo
 Post subject: Re: How to pass textvariable to GMIC from python
PostPosted: Thu Dec 30, 2021 6:36 am  (#2)
Hi nelo,
I'm don't know the syntax for GMIC calls, but shouldn't there be a comma between the parameters?
pdb.plug_in_gmic_qt(image,layer,1,1,"fx_watermark_visible,watermarktext,0.1568,50,25,0.5,1")
Charles
PostPosted: Thu Dec 30, 2021 8:42 am  (#3)
It should go like this:
pdb.plug_in_gmic_qt (image, drawable, 1, 0,   'fx_watermark_visible "Nelos Files",0.4,50,25,0.5,1')
Note the nested quotes ' ' around the " "
Attached my testing script. Find it in the tools menu - run gmic
for_gmic.zip [476 Bytes]
Downloaded 95 times
PostPosted: Thu Dec 30, 2021 9:37 am  (#4)
Thanks Rich,
That's what I already had and it only took the "hardcoded" text.
But I wanted it to be a variable, so the user can input what watermarktext they want.
Sorry if it wasn't clear enough.
Ok long story short.
I finally found this solution:
pdb.plug_in_gmic_qt(image,layer,1,0,"fx_watermark_visible {0},0.1568,50,25,0.5,1".format(watermarktext))
Regards
nelo
