It is currently Mon Nov 23, 2026 5:47 pm
 Post subject: New G'MIC filter "Tangential Circles"
PostPosted: Fri Sep 16, 2022 11:24 am  (#1)
Hello! :)
Inspired by this message, I intend to propose a new G'MIC filter "Tangential Circles".
With default parameters, it would give:
With default parameters except that "Number of Levels = 2, Effect = Blue-Cyan Halo", it would give:
With default parameters except that "Big Circle Radius = 150, Stroke Width = 2, Number of Levels = 2, Effect = Colored Tube", it would give:
Here is its code:
cl_circ_prerelease :
   # $1 : center x-coordinate
   # $2 : center y-coordinate
   # $3 : radius
   # $4 : stroke width
   fill. stroke(d)=cut($4-abs(d/2),0,1);stroke(sqrt((x-$1)^2+(y-$2)^2)-$3)
   n. 0,255
cl_innerCirc_prerelease :
   xC=$1 # center x-coordinate
   yC=$2 # center y-coordinate
   radi=$3 # big circle radius
   wid=$4 # stroke width
   nb=$5 # number of small circles
   lvl=$6 # number of levels
   if $lvl>0
      angl={pi/$nb}
      sinu={sin($angl)}
      ra={$radi/(1+1/$sinu)}
      ray={$radi/(1+$sinu)}
      +fill. 0
      [-1]x{$nb-1}
      foreach[1--1] {
         num=$>
         xA={$ray*cos(2*$num*$angl)}
         yA={$ray*sin(2*$num*$angl)}
         cl_circ_prerelease {$xC+$xA},{$yC+$yA},$ra,$wid
         cl_innerCirc_prerelease {$xC+$xA},{$yC+$yA},$ra,$wid,$nb,{$lvl-1}
   fi
#@gui ____<b>Rendering</b>
#@gui Tangential Circles (prerelease): cl_tangentialCircle_prerelease, cl_tangentialCircle_prerelease(1)
#@gui : note = note("<small>Warning: This is a slow filter.</small>")
#@gui : sep = separator()
#@gui : note = note("<b>Drawing:</b>")
#@gui : Big Circle Radius = float(100, 10, 500)
#@gui : Stroke Width = float(1,0.5,10)
#@gui : Number of Small Circles = int(5, 2, 20)
#@gui : Number of Levels = int(1, 1, 4)
#@gui : note = note("<b>Colors:</b>")
#@gui : Background Color = color(255,255,255)
#@gui : Foreground Color = color(0,0,0)
#@gui : note = note("<b>Effects:</b>")
#@gui : Effect = choice(0, "None", "Transparent Background", "Strange Polygon", "Multicolored", "Rainbow", "Double", "Colored Tube", "Red-Yellow Halo", "Blue-Cyan Halo")
#@gui : note = note("<small>Note: The preview might be much more aliased than the final result and some effects ignore colors.</small>")
#@gui : note = note("<small>Author: <i>Claude Lion</i>. Latest Update: <i>2022/09/11</i>.</small>")
#@gui : note = note("<small>It uses filters of David Tschumperlé and Rod/GimpChat and an algorithm of Reptorian.</small>")
cl_tangentialCircle_prerelease:
   radi,wid,nb,lvl,backR,backG,backB,foreR,foreG,foreB,effect=$*
   grow=3
   biggerRadi={$radi*$grow}
   if $effect==1
      $biggerRadi,$biggerRadi,1,4,255
   else
      $biggerRadi,$biggerRadi,1,3,255
   fi
   local.
      xC={w/2} # center x-coordinate
      yC={h/2} # center y-coordinate
      if $effect==1
         backR,backG,backB=$foreR,$foreG,$foreB
      elif $effect>=7
         backR,backG,backB=255,255,255
         foreR,foreG,foreB=0,0,0
      fi
      foreA=255
      backA={if($effect==1,0,255)}
      cl_circ_prerelease. $xC,$yC,$radi,$wid
      cl_innerCirc_prerelease. $xC,$yC,$radi,$wid,$nb,$lvl
      blend screen,1
      n. 0,1
      if $effect<=1
         fill. [i*$foreR+(1-i)*$backR,i*$foreG+(1-i)*$backG,i*$foreB+(1-i)*$backB,i*$foreA+(1-i)*$backA]
      elif $effect==2
         fx_rodilius. 15,1,0,$nb,90,0,1,0,0
         n. 0,1
         n. 0,255
      elif $effect==3
         fx_curvature 10,0,100,0,0
         fx_gradient2rgb 0,0,100,0,0
         apply_curve 1,0,0,16,240,255,255
         fx_smooth_antialias. 15,0,1,0,50,50
         fx_smooth_antialias. 50,50,2.5,0,50,50
      elif $effect==4
         fx_dog 1.4,1.5,0,0,0
         apply_curve 1,0,0,64,192,255,255
      elif $effect==5
         dog. 1.4,1.5
         n. 0,255
      elif $effect==6
         fx_dog. 1.4,1.5,0,0,0
         apply_curve. 1,0,0,16,0,255,255
         cut. 0,255
         fx_distance. 0,2,1,0
         negate. [-1] [-1]
         fx_decompose_channels 8,1,1,0
         l.
            # inspired by emboss_image of Reptorian
            +apply_curve. 1,0,0,240,16,255,255
            l.
               b. 2.5
               gradient2rgb. 0 n. 0,255
               [-1]
               rgb2hsv[-2,-1] split[-2,-1] c
               l[-3--1] +[-3] {315} %[-3] 360 done
               l[-6--4] +[-3] {135} %[-3] 360 done
               l[-3--1] a c hsv2rgb s c done
               l[-6--4] a c hsv2rgb s c done
               rm[^-6,-3]
               negate..
               / 2
               +. 128
               blend grainmerge,1
            done
            to_rgb
            blend grainmerge,1
         done
         sharpen 300
      elif $effect>=7
         remove_opacity.
         split. c rm. rm..
         +fx_morphological. 0,2,10,"1,0,1; 0,1,0; 1,0,1",0,0,0,0
         +fx_morphological. 0,2,20,"1,0,1; 0,1,0; 1,0,1",0,0,0,0
         if $effect==8 reverse[-3,-1] fi
         a c
      fi
   done
   mv[-1] 0
Installation:
  • Copy and paste the above code into the file "~/.gmic" on Linux or the file "%APPDATA%\user.gmic" on Windows.
  • The new filter appears in "Filters -> G'MIC -> Rendering -> Tangential Circles (prerelease)".
Have fun! :)
Photo to cartoon : https://github.com/cl4cnam/gimp_cartoon_plugin
 Post subject: Re: New G'MIC filter "Tangential Circles"
PostPosted: Sat Sep 17, 2022 1:49 am  (#2)
Nice addition to G'MIC! :bigthup Thx.
cl_tangentialCircle_prerelease 90.2,1.095,10,3,0,0,0,0,85,0,2
PostPosted: Sat Sep 17, 2022 2:04 am  (#3)
cl_tangentialCircle_prerelease 95.1,0.905,12,3,0,0,0,0,85,0,4
How do i insure the created image is my layer size? The image seems to crop itself to a certain width and length.
PostPosted: Sat Sep 17, 2022 2:06 am  (#4)
Looks cool; you probably made the Mandela lovers very happy with this one. :)
PostPosted: Sat Sep 17, 2022 12:53 pm  (#5)
What am I missing on how this filter is used? The layer arrangement produced at default places the result under the background image. Weird. I'll check it this time.
PostPosted: Sat Sep 17, 2022 2:24 pm  (#6)
Thanks Rod, lylejk, mahvin for your valuable feedback! :tyspin
Mahvin, for now, I can't reproduce your bug. What happens when you delete the last line of the code "mv[-1] 0" ?
PostPosted: Sun Sep 18, 2022 1:23 am  (#7)
Actually, I was missing the last line of code, and once added, it worked fine. However, like Rod asked, I'm curious how we can get the result to convert to the layer size we decide to use, since the display is rendering at 300px square.
PostPosted: Sun Sep 18, 2022 7:50 am  (#8)
I wonder if that has to do with the Big Circle Radius setting?
PostPosted: Sun Sep 18, 2022 8:01 am  (#9)
mahvin wrote:
...how we can get the result to convert to the layer size we decide to use...
I've just added a "Dimensions" parameter: Choose "According to Layer".
Here is the new code:
   # $3 : radius
   # $4 : stroke width
   n. 0,255
   if $lvl>0
      angl={pi/$nb}
      sinu={sin($angl)}
      +fill. 0
      [-1]x{$nb-1}
      foreach[1--1] {
         num=$>
   fi
#@gui : Dimensions = choice(0, "According to Radius", "According to Layer")
   radi,dime,wid,nb,lvl,backR,backG,backB,foreR,foreG,foreB,effect=$*
   grow=3
   rectWid={if($dime,w,$biggerRadi)}
   rectHei={if($dime,h,$biggerRadi)}
   chanNumb={if($effect,4,3)}
   $rectWid,$rectHei,1,$chanNumb,255
   local.
      if $effect==1
      elif $effect>=7
      fi
      foreA=255
      blend screen,1
      n. 0,1
      if $effect<=1
      elif $effect==2
         n. 0,1
         n. 0,255
      elif $effect==3
      elif $effect==4
      elif $effect==5
         dog. 1.4,1.5
         n. 0,255
      elif $effect==6
         cut. 0,255
         negate. [-1] [-1]
         l.
            l.
               b. 2.5
               [-1]
               rm[^-6,-3]
               negate..
               / 2
               +. 128
               blend grainmerge,1
            done
            to_rgb
            blend grainmerge,1
         done
         sharpen 300
      elif $effect>=7
         remove_opacity.
         split. c rm. rm..
         a c
      fi
   done
   mv[-1] 0
PostPosted: Sun Sep 18, 2022 9:05 am  (#10)
   # $3 : radius
   # $4 : stroke width
   n. 0,255
   if $lvl>0
      angl={pi/$nb}
      sinu={sin($angl)}
      +fill. 0
      [-1]x{$nb-1}
      foreach[1--1] {
         num=$>
   fi
   grow=3
   local.
      if $effect==1
      elif $effect>=7
      fi
      foreA=255
      blend screen,1
      n. 0,1
      if $effect<=1
      elif $effect==2
         n. 0,1
         n. 0,255
      elif $effect==3
      elif $effect==4
      elif $effect==5
         dog. 1.4,1.5
         n. 0,255
      elif $effect==6
         cut. 0,255
         negate. [-1] [-1]
         l.
            l.
               b. 2.5
               [-1]
               rm[^-6,-3]
               negate..
               / 2
               +. 128
               blend grainmerge,1
            done
            to_rgb
            blend grainmerge,1
         done
         sharpen 300
      elif $effect>=7
         remove_opacity.
         split. c rm. rm..
         a c
      fi
   done
   mv[-1] 0
Thank You! :bigthup
I was able to create a 375x375 circle by multiplying the # levels by Big Circle Radius. 3x125
I set my layer width and height to 375 and ran the filter with levels at 3 and Big Circle Radius at 125 and got an image very quickly. Exactly the width and height of my layer.
This computation cannot be correct however because i ran the filter with 3 levels and 500 Big Circle Radius on a 1500x1500 radius and got an error.
So i am not sure why it was not allowing those parameters.
Thanks for the update! :hi5
*** Error in ./cl_tangentialCircle_prerelease/ *** Command 'local': [instance(0,0,0,0,0000000000000000,non-shared)] gmic<float32>::assign(): Failed to allocate memory (15.3 Mio) for image (1000,1000,1,4).
For these settings
cl_tangentialCircle_prerelease 100,1,1,10,3,0,0,0,0,85,0,2
PostPosted: Sun Sep 18, 2022 9:17 am  (#11)
Odd though that running with preview on works in the filter,
but when i try to render the image (click Apply, Or OK).
I wonder if it's because i only have 500 MB of RAM on this Dell laptop. Can't be because of hard drive space as i have 42 GB of that.
:hoh :gaah
PostPosted: Sun Sep 18, 2022 9:26 am  (#12)
And when i try to run these settings using according to radius i get this error window with a 1500x1500 image size..
cl_tangentialCircle_prerelease 500,0,1,10,3,0,0,0,0,85,0,2
PostPosted: Sun Sep 18, 2022 9:38 am  (#13)
Ok i think i may have figured it out.
I reset the values of the filter.
I selected according to layer--no problem
I selected 10 for small circles
I selected 1 for levels no problem
I selected 2 for levels, no problem.
As soon as i selected 3 for levels G'MIC crashed.
Must be in the levels settings?
PostPosted: Sun Sep 18, 2022 9:50 am  (#14)
Nope! 2 on levels with a 1500x1500 image i get this.
Setting levels to 1 however...
PostPosted: Sun Sep 18, 2022 1:54 pm  (#15)
Just to illustrate the "Number of Levels" parameter:
With the "Dimensions" parameter set to "According to Radius", the width and height of the result are three times the radius. For now, this "three" factor is fixed (enough to let the effects go beyond the big circle):
@Rod
Yes, for now, my filter is not optimized and it consumes a lot of CPU and RAM.
I think I'll probably have to trace all the circles with a single 'fill' instruction.
PostPosted: Tue Sep 20, 2022 12:53 am  (#16)
@Rod
I still don't understand using just 1 level of circles it works but is very small compared to the layer size.
PostPosted: Tue Sep 20, 2022 5:27 am  (#17)
I think I get it now. :)
I've just added an option to the "Dimensions" parameter: "According to Layer (Proportionate)".
If you choose "Proportionate", the big circle radius is a percentage of 1/3 of the smaller dimension of the layer. Otherwise, it's a number of pixels.
   # $3 : radius
   # $4 : stroke width
   n. 0,255
   if $lvl>0
      angl={pi/$nb}
      sinu={sin($angl)}
      +fill. 0
      [-1]x{$nb-1}
      foreach[1--1] {
         num=$>
   fi
#@gui : note = note("<small>Warning: This is a slow filter and it might consume too much RAM.</small>")
#@gui : Dimensions = choice[0, "According to Radius", "According to Layer", "According to Layer (Proportionate)"]
#@gui : note = note("<small>If you choose "proportionate", the Big Circle Radius is a percentage of 1/3 of the smaller dimension of the layer. Otherwise, it is a number of pixels.</small>")
   grow=3
   dimens={$radi*$grow}
   rectWid={if($dime,w,$dimens)}
   rectHei={if($dime,h,$dimens)}
   radius={if($dime==2,$radi/300*min(w,h),$radi)}
   local.
      if $effect==1
      elif $effect>=7
      fi
      foreA=255
      cl_circ_prerelease. $xC,$yC,$radius,$wid
      cl_innerCirc_prerelease. $xC,$yC,$radius,$wid,$nb,$lvl
      blend screen,1
      n. 0,1
      if $effect<=1
      elif $effect==2
         n. 0,1
         n. 0,255
      elif $effect==3
      elif $effect==4
      elif $effect==5
         dog. 1.4,1.5
         n. 0,255
      elif $effect==6
         cut. 0,255
         negate. [-1] [-1]
         l.
            l.
               b. 2.5
               [-1]
               rm[^-6,-3]
               negate..
               / 2
               +. 128
               blend grainmerge,1
            done
            to_rgb
            blend grainmerge,1
         done
         sharpen 300
      elif $effect>=7
         remove_opacity.
         split. c rm. rm..
         a c
      fi
   done
   mv[-1] 0
PostPosted: Tue Sep 20, 2022 10:43 am  (#18)
   # $3 : radius
   # $4 : stroke width
   n. 0,255
   if $lvl>0
      angl={pi/$nb}
      sinu={sin($angl)}
      +fill. 0
      [-1]x{$nb-1}
      foreach[1--1] {
         num=$>
   fi
   grow=3
   local.
      if $effect==1
      elif $effect>=7
      fi
      foreA=255
      blend screen,1
      n. 0,1
      if $effect<=1
      elif $effect==2
         n. 0,1
         n. 0,255
      elif $effect==3
      elif $effect==4
      elif $effect==5
         dog. 1.4,1.5
         n. 0,255
      elif $effect==6
         cut. 0,255
         negate. [-1] [-1]
         l.
            l.
               b. 2.5
               [-1]
               rm[^-6,-3]
               negate..
               / 2
               +. 128
               blend grainmerge,1
            done
            to_rgb
            blend grainmerge,1
         done
         sharpen 300
      elif $effect>=7
         remove_opacity.
         split. c rm. rm..
         a c
      fi
   done
   mv[-1] 0
Sorry. With these settings i still get an error. :(
cl_tangentialCircle_prerelease 100,2,1,10,3,255,255,255,0,0,0,0
Has to be my RAM output. :(
PostPosted: Tue Sep 20, 2022 10:50 am  (#19)
As long as i use 1 level it works. But now i have no nifty design. :gaah :hoh
cl_tangentialCircle_prerelease 100,2,1,10,1,0,0,0,0,85,0,2
PostPosted: Tue Sep 20, 2022 10:55 am  (#20)
