It is currently Mon Nov 23, 2026 4:42 pm
 Post subject: Wild Cartoonizer by PhotoComix
PostPosted: Sat Jul 15, 2023 12:36 pm  (#1)
https://discuss.pixls.us/ is on vacation :cool (unavailable) so I'm posting here:
A little problem (Gimp-2.10.34 Win 64bit, G'MIC-QT -3.2.6)
Testing ➤ PhotoComix ➤ Wild Cartoonizer
If use Output mode = in place
add new layer
If use Output mode = new layers or new active layers or new image
creates two new layers
 Post subject: Re: Wild Cartoonizer by PhotoComix
PostPosted: Sat Jul 15, 2023 12:44 pm  (#2)
add new layer
The link provided seems to give errors.
Reloading the page also gives the same error.
PostPosted: Tue Jul 18, 2023 6:20 am  (#3)
add new layer
Yes. This occurs with me using G'MIC 3.2.3#pre230408 and G'MIC 3.2.7. The layer doubling is annoying but apparently harmless. The plug-in operates as advertised, otherwise. If time permits this week, perhaps I can address the issue. Thank you for noticing and posting.
As for discuss.pixls.us, I have little to add. The last activity I had with the site was Thursday, 7/13 at about 18:00 UTC; it was dark by 7/14, 10:00 UTC and remains so at this writing. The site `patdavid.net`, served by the same host, is also dark. I hope all is well with Pat.
PostPosted: Wed Jul 19, 2023 8:58 am  (#4)
@grosood.
Thank you for your interest.
I will wait patiently.
PostPosted: Thu Jul 20, 2023 1:40 am  (#5)
regarding pixls.us see here:
https://www.gimp-forum.net/Thread-Pixls ... 2#pid35242
Regards
nelo
PostPosted: Thu Jul 20, 2023 2:04 am  (#6)
Still down :(
Five Oh Three
You are seeing this because patdavid lost our 503 page and darix is probably working on something, but oh well the weather is nice outside.
PostPosted: Thu Jul 20, 2023 11:30 am  (#7)
sallyanne wrote:
Still down :(
Five Oh Three
Progress, though. That means a basic web server is running, but the web application isn't up yet. (As of this writing, 16:27 UTC, the root page is up, but discuss.pixls.us still shows "503."
Thank you for the progress link, nelo.
PostPosted: Thu Jul 20, 2023 12:50 pm  (#8)
Miss PC; hard to believe it's now over a decade since I've seen any post from him.
Don't often check PixLS (when I don't, after a few weeks I usually get an email sent to me telling all the new posts there; lol). Had no idea the site went dark; hope all's right. PatDavid is a member here; hopefully someone sent him a PM to see what's going on. :)
PostPosted: Thu Jul 20, 2023 12:54 pm  (#9)
OK; checked nelo's link and Pat posted 9 hours ago so hopefully soon, PixLS will be back. It's partually up now; just not Discuss part. :)
PostPosted: Sun Jul 23, 2023 5:11 am  (#10)
Updated in 3.2.7 (Currently pre-release)
Merge branch fixphotocomix: Wild Cartoonizer
A one-line fix following Tas-Mania's suggestion in this thread: 2021-15-February, GMIC Wild cartoonizer Photocomix.
I suspect PC intended to blend the two images into one as a final step; educated guess that an overlay blend best fit his purposes. Because of the blend, there are vanishingly small differences between this and 3.2.6 behavior.
Available with a filter update to those on the 3.2.7 bleeding edge; generally available when 3.2.7 goes fully live. Take care.
PostPosted: Mon Jul 24, 2023 1:09 am  (#11)
I didn't know it was such an old problem.
All the more thanks for solving it. :tyspin
After updating filters in GMIC 3.2.6 it works as expected. :bigthup
