It is currently Mon Nov 23, 2026 3:42 pm
 Post subject: Release of G'MIC 3.3
PostPosted: Tue Sep 05, 2023 1:03 am  (#1)
Hello GimpChat folks !
I would like to announce the release of a new version of G'MIC, numbered 3.3.0.
It was released yesterday, and I'm very happy with it :mrgreen:
Do not hesitate to upgrade if you are using this plug-in for GIMP, as new filter updates will be pushed only for this new version in the future.
Cheers,
David.
 Post subject: Re: Release of G'MIC 3.3
PostPosted: Tue Sep 05, 2023 2:20 am  (#2)
Thanks a lot David !
PostPosted: Tue Sep 05, 2023 2:33 am  (#3)
Applied to my Gimp (samj's version) but I get this message:
are there some .dll missing?
the snapshot is in Italian, but I guess you understand the name of .dll missing (which could be not the only one)
edit: or should I wait for a samj's pack release containing 3.3?
PostPosted: Tue Sep 05, 2023 2:36 am  (#4)
Thanks David for this great app :bigthup
If anyone is worried about a G'MIC filter being dropped they can put it into their local folder in the .gmic file. :)
PostPosted: Tue Sep 05, 2023 2:54 am  (#5)
No idea, I don't use the samj's version.
If you need to get additional .dll, you may try downloading the archive for the stand-alone version of G'MIC-Qt, here : https://www.fosshub.com/GMIC.html?dwl=g ... _win64.zip
It contains all the necessary .dll to make G'MIC-Qt work.
PostPosted: Tue Sep 05, 2023 2:59 am  (#6)
Thanks, David.
PostPosted: Tue Sep 05, 2023 3:15 am  (#7)
GOOD ! It worked (just copied two dll's what were missing, at startup)
PostPosted: Wed Sep 06, 2023 5:41 pm  (#8)
I'm glad I put Reptorians 'Channel Overblur' into my own gmic file because it's no longer in G'MIC 3.3.
This fllter could almost do iridescence and luminescence which are absent from both Gimp and G'MIC.
4WD made by AI.
Image with default channel overblur settings.
PostPosted: Wed Sep 06, 2023 6:28 pm  (#9)
Online
Guess I'm late to the party; new version works great. :)
PostPosted: Fri Sep 08, 2023 4:09 am  (#10)
Working great in Debian Bullseye - thank you!
