It is currently Mon Nov 23, 2026 6:33 am
 Post subject: New G'MIC filter "Rendering / Neon Carpet"
PostPosted: Sun Dec 08, 2024 10:22 am  (#1)
Hi everyone! :)
I intend to add a new G'MIC filter "Rendering / Neon Carpet".
With default parameters, on a 800x600 layer, it would give:
Here is its code:
#@gui ____<b>Rendering</b>
#@gui Neon Carpet (prerelease): cl_neonCarpet_prerelease, cl_neonCarpet_prerelease(0)
#@gui : Sequence Number = ~int(0, 0, 200)
#@gui : Item Number = ~int(0, 0, 100)
#@gui : Invert = ~bool(0)
#@gui : sep = separator()
#@gui : note = note("Note: Some combinations of parameters give a completely black result")
#@gui : note = note("<small>Author: <i>Claude Lion</i>. Latest Update: <i>2024/12/08</i>.</small>")
#@gui : note = note["<small>It uses filters of David Tschumperlé and Andy Kelday (garagecoder)</small>"]
cl_neonCarpet_prerelease:
   num1,num2,inv=$"*"
   foreach {
      fact2={11+2*$num2}
      fact1={$fact2+$num1}
      fill. "(x*x+y*y+128*c)%512%"$fact1"%"$fact2
      n. 0,256
      distance. 128,3
      %. 32
      n. 0,255
      b. 1.1
      ac "repeat 6 { bilateral 10,7 }",0 # copied from "fx_smooth_bilateral 10,7,6,0" of David Tschumperlé
      cut. 0,100
      n. 0,255
      # copied from "gcd_despeckle 20,20" of Andy Kelday (garagecoder)
      +label. 20,1 nb={1+iM}
      +histogram. $nb,0,{$nb-1}
      map.. . rm.
      le. 20 *. 255
      inpaint.. . rm.
      # end of copy from garagecoder
      if $inv==1
         negate. n. 0,255
      fi
Installation:
  • Copy and paste the above code into the file "~/.gmic" on Linux or the file "%USERPROFILE%\user.gmic" on Windows.
  • The new filter appears in "Filters -> G'MIC -> Rendering -> Rendering / Neon Carpet (prerelease)".
or you can use the new option.
Have fun! :)
Photo to cartoon : https://github.com/cl4cnam/gimp_cartoon_plugin
 Post subject: Re: New G'MIC filter "Rendering / Neon Carpet"
PostPosted: Wed Dec 11, 2024 9:14 am  (#2)
Are you able to use the filter?
PostPosted: Wed Dec 11, 2024 9:36 am  (#3)
Yes!
PostPosted: Wed Dec 11, 2024 12:31 pm  (#4)
That's not the result I expected. I have to find the reason of that bug.
With your parameters, I obtain this:
PostPosted: Wed Dec 11, 2024 1:36 pm  (#5)
Is the bug fixed with this version?
#@gui : note = note("<small>Author: <i>Claude Lion</i>. Latest Update: <i>2024/12/11</i>.</small>")
   num1,num2,inv=$"*"
   foreach {
      remove_opacity.
      fact2={11+2*$num2}
      n. 0,256
      distance. 128,3
      %. 32
      n. 0,255
      b. 1.1
      cut. 0,100
      n. 0,255
      map.. . rm.
      le. 20 *. 255
      inpaint.. . rm.
      if $inv==1
         negate. n. 0,255
      fi
PostPosted: Wed Dec 11, 2024 1:47 pm  (#6)
Yes, it looks like yours now
PostPosted: Wed Dec 11, 2024 1:55 pm  (#7)
:coolthup Thanks to you, I've fixed the bug, thank you! :tyspin
PostPosted: Fri Dec 13, 2024 1:47 am  (#8)
nice
PostPosted: Sun Dec 15, 2024 10:46 am  (#9)
Thanks, Sallyanne :)
@everyone
Have you experienced any other bugs?
PostPosted: Sun Dec 15, 2024 3:16 pm  (#10)
Seems to work fine.
Looks nice in monochrome, too:
Removed the black background, then coloured the remainders white.
Put a coloured layer underneath. Voilà.
Looks a bit like embroidered ...
PostPosted: Tue Dec 17, 2024 2:52 pm  (#11)
:tyspin
PostPosted: Tue Dec 17, 2024 10:23 pm  (#12)
MareroQ wrote:
:tyspin
:jumpclap
PostPosted: Fri Dec 20, 2024 8:22 am  (#13)
Thanks, Quietreader, MareroQ and Wallace :tyspin
Now, the filter is included in version 3.5.0_pre of G'MIC.
