It is currently Mon Nov 23, 2026 5:03 am
 Post subject: type of drawing from a photo
PostPosted: Tue Jan 07, 2025 5:03 pm  (#1)
Hello,
How can I make this type of drawing from a photo? You would need clothes with less detail and strokes towards the drawing.
Do you have a filter for this ?
thank you for your suggestions
portrait-de-famille-dessin-en-noir-et-blanc-1200-x-1200.jpeg [ 164.47 KiB | Viewed 6171 times ]
 Post subject: Re: type of drawing from a photo
PostPosted: Wed Jan 08, 2025 5:31 pm  (#2)
Hello Miguel :)
I propose you copy and paste this into "G'MIC -> Various -> Custom Code [Full]":
+cl_comic. 0,2,0,1,1,15,15,0,10,20,6,2,0,0,0,0,0,0
mul. [-2]
rm..
fx_smooth_nlmeans. 4,4,10,3,0,0,24
fx_blackandwhite. 0.299,0,0.587,0,0.114,0,0,0,0,0,0,0,0,0,2,0,0,0,16,4,0,0
Hope it helps. :)
Photo to cartoon : https://github.com/cl4cnam/gimp_cartoon_plugin
PostPosted: Wed Jan 08, 2025 9:14 pm  (#3)
Upscayled David (he incs.reference picture in G'MIC), ran B/W Freaky Details and then did 2 passes of Illustration Look (all G'MIC). Can get more of an illustrative look if you like. :)
PostPosted: Thu Jan 09, 2025 3:50 am  (#4)
I have another way which I typed in hours ago but never sent.
Desaturate your photo the in G'mic-Qt use Telperion's 'Mc Pendraw' which is under testing. Back into gimp cartoon.
PostPosted: Thu Jan 09, 2025 3:34 pm  (#5)
hi,
I forgot this filter illustrative look
thanks
PostPosted: Sat Jan 11, 2025 6:05 pm  (#6)
I've made a mistake (I think I've copied and pasted an old try), here is the fix:
mul. [-2]
rm..
n. 0,255
PostPosted: Sun Jan 12, 2025 9:45 pm  (#7)
Hello,
Thanks for your answers.
I played each answer in a video Youtube. Lylejk's is the closest to my request.
Lylejk
https://youtu.be/_Pr69R9D2wQ
Sallyanne
https://youtu.be/9TlwQohxgQM
cli345
https://youtu.be/fTmXn-iFDDE
kind regards,
Miguel
PostPosted: Tue Jan 14, 2025 12:14 am  (#8)
Saw the video (at work) earlier, Miguel. Thanks for sharing the link. Not a polyglot (happen to actually see this term earlier; lol), but understood your flow none the less. :)
