It is currently Mon Nov 23, 2026 3:51 am
 Post subject: Cartesian Transform
PostPosted: Sat Jan 18, 2025 7:05 am  (#1)
On Gimp-Forum.net denzjos pointed out a very nice page (not only about Gimp):
https://screamingbrainstudios.com/cartesian-transform/
A lot of examples and explanations including:
G'MIC-Qt / Deformations / Cartesian Transform
A bit out of date because the formulas will not work if they contain the letter a - but it will be enough to change it to another one (after the update in 2023 A, B, C, D are reserved for constants).
I am fascinated by the power of this filter.
Maybe someone knows other pages on this topic?
 Post subject: Re: Cartesian Transform
PostPosted: Sun Jan 19, 2025 1:08 am  (#2)
It is also an inexhaustible possibility of creating animations.
Animation examples reduced to the limitations of attachments.
How to easily write plugins to create animations from G'mic (a few lines of code), you can see in Animation_cartesian_transform.py
Animation_cartesian_transform.zip [1.06 KiB]
Downloaded 210 times
PostPosted: Mon Jan 20, 2025 1:12 am  (#3)
Rotating Ball
Type: Circle Transform
Type: Spherize
Cartesian_transform_rotating_ball.zip [1.18 KiB]
Downloaded 195 times
PostPosted: Wed Jan 22, 2025 2:59 am  (#4)
Circular Ripple
Cartesian_transform_Circular_Ripple.zip [1.08 KiB]
Downloaded 194 times
PostPosted: Wed Jan 22, 2025 4:14 am  (#5)
MareroQ, Thanks a lot for your plug-ins. :hi5
PostPosted: Wed Jan 22, 2025 7:58 am  (#6)
Thank you so much Isabella for playing with me :hi5
PostPosted: Wed Jan 22, 2025 7:59 am  (#7)
Concave Warp
Zoom Bulge
cartesian_transform_Zoom_Bulge.zip [1.1 KiB]
Downloaded 200 times
Cartesian_transform__Concave_Warp.zip [1.07 KiB]
Downloaded 196 times
PostPosted: Wed Jan 22, 2025 10:49 am  (#8)
It's really funny, MareroQ. Thank you so much. :tyspin :coolthup
PostPosted: Wed Jan 22, 2025 4:49 pm  (#9)
I want to learn too.
PostPosted: Thu Jan 23, 2025 5:16 am  (#10)
Yo también quiero aprender.
:clap , ask if you need some help. :hi5
PostPosted: Fri Jan 24, 2025 3:51 am  (#11)
Am I missing something?
PostPosted: Fri Jan 24, 2025 6:31 am  (#12)
Don't be discouraged because you are on the right track. :hi5
It's just that after obtaining the layers (let's say 10 layers) you leave layer 10 as it is and now you reverse the layers to get the opposite effect.
Layer 10 as it is, layer 9 you duplicate it and place it on top of layer 10, which will be layer 11. Layer 8 you duplicate it and place it on top of layer 11, which will be layer 12...and so on until the original image layer.
You give the top layer a pause of (1000ms) so as not to overwhelm the effect.
It's that easy.
Good luck, DJ :)
PostPosted: Sun Jan 26, 2025 6:07 am  (#13)
Making a Ping-Pong effect is time-consuming - there are various plugins for it.
I'm posting the simplest version here (without GUI).
In the menu:
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
Spiral Riple
The Radial Slice preset lets you create two types of seamless images:
1. Relative Warping
Source:
Result:
2. Radial
Source:
Result:
These new interesting possibilities of creating seamless textures and many types of deformations have been added to MrQ Pattern Editor Ver.11Ver.11.
Ping-Pong Layers.zip [883 Bytes]
Cartesian_transform_Spiral_Riple.zip [1.09 KiB]
Downloaded 221 times
PostPosted: Sun Jan 26, 2025 11:36 am  (#14)
Hi MareroQ, thanks for your new filter.
It seems that I can't enjoy it because I don't have version 3.5 installed
Even though I have installed it, it's not visible in the layers list.
My Gmic version is 3.3.5
Thanks anyway. :tyspin
PostPosted: Sun Jan 26, 2025 9:28 pm  (#15)
Hi Issabella
I didn't understand which filter doesn't appear in the menu?
Registration in the menu itself doesn't depend on the G'MIC version.
All animation filters listed here have a location:
Filters ➤ Animations ➤ Cartesian Transform 'Name'...
The Ping Pong plugin is located in the Layers context menu (right mouse button).
PostPosted: Mon Jan 27, 2025 3:32 am  (#16)
Thank you so much MareroQ.
My problem is that having the filter installed, I can't see it. it doesn't show in the list.
I don't know the reason.
Please, see the shots.
PostPosted: Mon Jan 27, 2025 4:32 am  (#17)
OK.
I wasn't specific enough in the description. ;)
You need to click on the layer in the Layers dock.
Notice the difference between Layer and Layers. :yes
Just in case, I'm including the version that registers in the menu:
Filters➤Animation➤Ping-Pong Layers for Animation
(You can keep both versions).
Ping-Pong Layers for animation.zip [924 Bytes]
Downloaded 193 times
PostPosted: Mon Jan 27, 2025 4:38 am  (#18)
Just, It was that. :jumpclap
Happy with the result and a helpful filter, MareroQ.
Thank you so much :tyspin :hi5
PostPosted: Mon Jan 27, 2025 4:46 am  (#19)
Just I have installed your other filter to keep both. Thank you so much. :tyspin :coolthup
