It is currently Sat Nov 21, 2026 5:59 am
 Post subject: How to install G'MIC 3.5.3 in GIMP 3.0.2 in Mac and linux ?
PostPosted: Wed Mar 26, 2025 3:39 pm  (#1)
Hello everyone!
I wanted to know if there is a way to install G'MIC 3.5.3 in GIMP 3.0.2 in Mac and linux ?
or is it available only for Windows ?
thanks so much in advance!
 Post subject: Re: How to install G'MIC 3.5.3 in GIMP 3.0.2 in Mac and linux ?
PostPosted: Thu Mar 27, 2025 11:06 am  (#2)
I, too, am in search for a GMIC version for Linux Mint 21 (Ubuntu Jammy) for a GIMP 3.0.2 from Panda Jim PPA.
Nothing there on gmic.eu
PostPosted: Tue Apr 08, 2025 5:57 am  (#3)
I checked gmic.eu and looks like they added the zipfile for Linux Ubuntu 25.04 Plucky and Debian 13 Trixie
hope they add the one you need soon!
PostPosted: Tue Apr 08, 2025 9:11 am  (#4)
David does not add the plugin unless the version of Gimp is the default for the particular distro. ( so a PPA is no good for him)
I had some problem with the latest gmic 3.5.3 code / PandaJim dev So I went back to gmic_gimp_qt 3.5.0 and that compiles in a Mint 21 VM Better than nothing: ;)
Download from my cloud account https://u.pcloud.link/publink/show?code ... HuThCnwrAy
About 5.5 MB zipped, unzip and put the whole gmic_gimp_qt folder in your Gimp 3 user plugins folder
PostPosted: Tue Apr 08, 2025 9:21 am  (#5)
Thank you so much for this, Rich.
PostPosted: Sun May 11, 2025 10:07 am  (#6)
Appreciated the post Rich. I am new to Gimp and GimpChat but stumbled across this thread and hoped it would solve my difficulties installing GMIC in Gimp. I downloaded your folder and its included gmic-gimp-qt file. The folder was placed in my user Library/Application Support/Gimp/plug-ins folder. Gimp was started, but GMIC does not appear in the Filter menu.
A plugin I installed yesterday, new layer from selection, in the same location does show up in the Layer menu.
I am running Sequoia 15.4.1 on a new MacBook M4 Pro. Gimp is version 3.02
Welcome any advice you might have.
PostPosted: Sun May 11, 2025 3:24 pm  (#7)
Thanks rich2005! Finally a G'mic that actually works in Linux. Much appreciated..........
cron
