It is currently Mon Nov 23, 2026 1:44 am
 Post subject: paper cuts
PostPosted: Mon Apr 21, 2025 8:38 am  (#1)
With Gmic 3.5.3 and "Paper Cuts"
in Gimp 3.0.2 and Gimp 2.10.38
 Post subject: Re: paper cuts
PostPosted: Mon Apr 21, 2025 11:17 am  (#2)
With what specific settings?
It works fine for me for Gimp 2.10.38 and Gimp3.0.2
PostPosted: Mon Apr 21, 2025 2:21 pm  (#3)
@level_0
I get that error as well - linux Gimp 2.10.38 / Gimp 3.0.2 with gmic_gimp_qt 3.5.3
I did get it to work Gimp 2.10.38 with a gmic_gimp_3.2.0 version. (you need to update and earlier versions not possible)
There might be later versions also working, I do not know.
Maybe David Tschumperlé will fix.
Edit: hmmm...both 2.10 and 3.0 in a terminal
/home/rich/gimp30/plugins/gmic_gimp_qt/gmic_gimp_qt: fatal error: Segmentation fault
/home/rich/gimp210/plugin/gmic_gimp_qt: fatal error: Segmentation fault
PostPosted: Mon Apr 21, 2025 3:23 pm  (#4)
Mareroq :wvy
With default settings ;)
rich2005 :wvy
cron
