It is currently Thu Nov 19, 2026 5:34 am
 Post subject: Gmic 4.0.5 mot showing under filter. Usin GIMP 3.2.6 (solved)
PostPosted: Fri Sep 25, 2026 3:27 pm  (#1)
Recently upgraded to GIMP 3.2.6 and also downloaded a new Gmic 4.0.5. I am unable to get it to appear under 'filters'. I have tried to fix this for a week now. Unable to fix. Need help.
 Post subject: Re: Gmic 4.0.5 mot showing under filter. Usin GIMP 3.2.6
PostPosted: Fri Sep 25, 2026 8:43 pm  (#2)
G'MIC 4.0.5 does support GIMP 3,
and the current official download specifically provides a G'MIC-Qt plug-in for GIMP 3.
Try using the ZIP package and install it manually.
https://gmic.eu/download.html
PostPosted: Fri Sep 25, 2026 8:55 pm  (#3)
Thanks for replying... Yes, this is the one I downloaded. However, I still do not see G'Mic under the filter tab. :(
PostPosted: Fri Sep 25, 2026 10:54 pm  (#4)
When it asks for the plug-in location, use:
C:\Users\<YourName>\AppData\Roaming\GIMP\3.2\plug-ins\gmic_gimp_qt
Replace <YourName> with your Windows user name.
Finish the install,
restart GIMP,
G'MIC-Qt should show up under Filters.
If it doesn't,
You could also check what was actually installed.
Go to:
Check to see what files are in there.
File comment: Screenshot of my plug-ins 3.0 folder
PostPosted: Fri Sep 25, 2026 11:23 pm  (#5)
Check your files in these locations... G-MIC-QT
and here, make sure the folder name matching the exe file name.
That runs the program, with in that folder,
and here
All I did was unzip the files, then I copy them to my Plugin Folder.
Updating what was there. I have no problems with it loading and self-updating.
Intel(R) Core(TM) Ultra 7
PostPosted: Sat Sep 26, 2026 1:17 pm  (#6)
I thank you very much. You took the time to post all those folders. However, my setup is exactly like yours (plus a couple more files is some folder which would not create this issue). As mentioned in my first post, I have been working on this issue for over a week now and still no results. Very frustrating. I deleted the old gmic, reinstalled it using the exe file, did not work so deleted it again and used the zip download file. Still no result. Frustrating. :)
PostPosted: Sat Sep 26, 2026 9:07 pm  (#7)
After 9 days, finally found the problem. The program was set to run as administrator. All I had to do is uncheck that box, apply, ok. Restart GIMP and it showed... I can now dance...
PostPosted: Sun Sep 27, 2026 9:35 am  (#8)
I can now dance...
I'm happy you figured this one out.
This is good info for future reference about G'mic installation issues.
I also marked it as "solved".
However,
this isn't usual behavior for a G'mic installation to change itself to run as admin.
So I'm not sure what's going on there.
Anyway,
sorry this took so long for you to setup and get running.
